Drain plug keeps turning
Old Sep 18, 2012 | 11:58 PM
  #41
HondaProtegeX2.3's Avatar
B A N N E D
Originally Posted by HondaProtegeX2.3
my bad
this is my mugen this part added 50 whp from what my friend told me.
https://acurazine.com/forums/picture...ictureid=56032
Old Sep 18, 2012 | 11:59 PM
  #42
mmakam2's Avatar
I didn't read the thread, but going by the title of the thread, I highly recommend using a hela coil to repair the thread. You can get a kit from Napa, and it will retain the original bolt and thread size.
basically, you tap out the hole with the tap provided, thread in a coil, then the original bolt will screw right in, and will be waaay stronger than just an oversized bolt. I've used hela coils on engine mounts, and ive heard of people using em on head bolts so they are definetly strong
Old Sep 19, 2012 | 12:02 AM
  #43
B A N N E D
I wondered what they were talkin about helicoil stuff. but thanks I hope I dont have to ever fix this issue again so next time I will be the only one removeing the drain bolt when we do oil changes and I will bring a 17mm wrench of my own so I know i can use the closed end of the wrench and carefully remove and install the drain bolt back securely with out hurting the threads
Old Sep 19, 2012 | 12:04 AM
  #44
B A N N E D
yea Im going to try and new pan route cause I just got it in the mail Monday so Im bringing it first thing tomorrow morning to get it all tooken care of by the shop that does the oil changes. pretty much they saids its wear and tear and that its aluminum and yada yada Im like ok well lets fix it and get it over with... so Im paying 50% of what the master mechanic quotes the job for... they said its probably most 4 hrs of labor.. Im thinking maybe 2-3 max
Old Sep 19, 2012 | 07:06 AM
  #45
3.2TLc's Avatar
Hey man, buy a 6 point swivel socket wrench......paint it fluorescent orange and place it in your glove box. Better to be the person turning the wrench as you learned the hard way !
Old Sep 21, 2012 | 10:50 PM
  #46
B A N N E D
Ya well I took it back and they said I would have to pay 50% of the cost of the normal labor rate. I think my car is leaking Power steering fluid more then anything now... It does seem like a PITA and not really worth changing cause the pan is still good so I got this extra pan just in case I ever really need it in case of emergency, Im in the process of trying to get a new car so if i do my bro will be the lucky young lad to own my fine acura tl I will teach him to respect the car as much as possible so that it last at long as it can...
Hopefully everything falls thru pretty soon to get a new ride.
Old Sep 22, 2012 | 02:02 AM
  #47
01tl4tl's Avatar
no its not wear and tear IF the correct torque of 29 foot pounds (not the 50+ they did) has been applied each time, it wont hurt the aluminum in any way!!!!!!!!!!!!!!!!!!!!
there is no regular wear out time of the oil pan threads!!!!!
they effed your car man,,
how can they try to get away with charging you??--when it could easily have been a new engine at their expense when that leak became full scale blowout!
And what about that--we will take care of it if needed bs they told you before?
heard of the BBB? (if they belong) and the state bureau of auto repair-licensing
they would be interested in this theory of drain plug wearout!
Old Sep 22, 2012 | 07:26 AM
  #48
B A N N E D
ya i take my cars to them all the time to, i spent unlimited amounts of money at this shop, seems lime if my car dont need something. and i tryin.fixing something it gets worse then i got to spend more money, imma make em fix it asap.. just kinda got ping ponged around
Old Sep 22, 2012 | 09:26 AM
  #49
01tl4tl's Avatar
they owe you for the oil pan purchase, free install, plus an oil change with new filter--in case stuff has been floating around from thread shavings
their total labor cost 50 bucks, parts 10 plus oil pan
I ran a shop for years,,this is the way the shop SHOULD handle it, if owner wants to stay out of small claims court- where customer always wins! and more than cost of repair~
much cheaper to just do it right and keep the customer happy,
TRAIN/ retrain staff to use actual torque gauge on ALL bolts- not blast on as tight as possible with the air gun (rips threads from pan)
or a huge long wrench generating 100 foot pounds by same grunt installer who put the oil filter on so tight its squished the oring seal~ needs screwdriver punched thru to spin filter off!!!!,,yeah,,,,,, that guy got the drain plug perfect tight spec
every single bolt has a spec torque,,bolts actually stretch!!
and torque spec is where they belong,,not 10 20 50 100 pounds over spec
oil and atf drains are 29 foot pounds on the TL,,
wheel lugs are 80 = for referance of how tight your oil plug probably was
Old Sep 22, 2012 | 02:04 PM
  #50
B A N N E D
lol, ya i know what you mean they messed it up and it needs to be fixed i wish i would do the work myself but why. Imma just go in and explain tq specs on the pan but I never seen any shop use tq wrenches on oil changes then again I never take my car anywhere else for maintance work for a fact, I know I take my car in alot and they always have a ”hooked up” price ill get it fixed soon esp before i move to a new car n im tryin to obtain and give my brother the accord and maybe keep the type s and new car. Ya I got the pan so they should install it at least now imma take it sunday or monday tho for sure
Old Sep 22, 2012 | 03:35 PM
  #51
01tl4tl's Avatar
you dont have a lift at home for this job
the hookup price,,another great piece of bs fed to customers
Old Sep 22, 2012 | 04:42 PM
  #52
MilwaukeeDave's Avatar
There's a place I found by me that rents lift bays w a set of tools. I used their facilitiy to install my headers and rear mount and holy shit was I happy to have a lift for those jobs. I couldn't imagine turning the wrench for those on my back. It was 36 bucks an hour so not too terrible at all. I think there needs to be more places for DIY available.
Old Sep 22, 2012 | 05:34 PM
  #53
B A N N E D
ya so there price is 200.00 so i got to pay 100.00 sure if i gave em 80.00 they would be cool with that i shouldnt of had to pay anything.. man i should just call acura see what they would charge or honda. im sure the shop tho will be able to install it for less cause thats bs.
Old Sep 22, 2012 | 05:36 PM
  #54
B A N N E D
just got to bring it in monday maybe wedsay they said early
Old Sep 22, 2012 | 11:46 PM
  #55
B A N N E D
ya man its all good they gonna have to eat the cost up alot better Im willing to give a some dough I already spend alot I looked at my reciets just yesterday I spent like 600 cash on a bunch of stuff that I did to my tl front and rear brakes and some tires, radiator flush and a oil change. and all I have been able to afford is the maintenance but this has been the car I took the best care of out of the ton of cars I have owned.
mada51589
Jan 9, 2025 04:40 PM
Padre
Sep 19, 2015 09:08 AM
PortlandRL
Sep 14, 2015 12:01 PM
mc1114
Sep 11, 2015 05:50 PM
quake97
Aug 30, 2015 07:57 PM
