DIY : EVAP Canister & Shut Valve Replace ?
Old Feb 16, 2009 | 06:04 PM
smartypants's Avatar
Hi All :
Has anyone changed their EVAP Canister and Shut valve ? What are the tips & tricks ?
Thanks to all in advance.
smartypants.
Old Feb 26, 2009 | 08:44 PM
How do you change the shut valve and canister ?
Hi All :
Anyone ever changed out a shut valve and evap canister ? Anything I should watch out for ?
Thanks to all who reply !
smartypants
Old Feb 26, 2009 | 10:55 PM
sbuswell's Avatar
I need 2 more gears
i'd like to do know too. I'll be checking mine out on saturday and hopefully I ca figure it out myself and report back here.
Old Mar 2, 2009 | 08:23 PM
Hi All :
Anyone else have any comments ?
Thanks in advance.
smartypants
Old Mar 2, 2009 | 10:44 PM
sbuswell's Avatar
I need 2 more gears
I didn't see anything wrong visually. I've been paying extra attention to how many times I turn my gas cap when fueling up(3 clicks only) and the code hasn't come back.
Old Mar 3, 2009 | 12:09 AM
thinhthan's Avatar
is it nessary to change the evap canister and stuff?
Old Mar 5, 2009 | 05:02 PM
Hi Thin :
We don't really have a choice. Once the RRI (Recurring Revenue Indicator) light comes on, we have to rectify the issue by replacing parts or take it to the stealership and say "do me !". In my case I'm getting a P1457 code which is related to the EVAP canister (I hope).
smartypants
Old May 27, 2009 | 11:22 AM
Code 1457 - Need Help to Replace EVAP Canister & Shut Valve
Hi All :
I sent out this request for help a while ago and have now received the EVAP Canister and Shut Valve parts. Has anyone replaced these parts and can offer any advice ? I'm trying to solve a code 1457 which is a "major evap leak".
Since I don't have any of the required vacuum testing equipment, I'm pretty much going to change out the parts and hope the code goes away, unless anyone has any other ways of testing the system using more common tools. I might even try sucking or blowing into the tubes to see if there are any leaks. Again, I'm very much in the dark as to how this system works and how it should behave.
Any pics or tips would be very helpful.
smartypants.
Old May 27, 2009 | 08:12 PM
acurabum's Avatar
What year is your TL ? My 02 TLP got the P1457 and I did search and decide to change the Canister set P/N 17011-S84-A00 and Canister Vent Shut Valve P/N 17310-S0X-A02.
It's a very easy repair .
Old May 27, 2009 | 08:19 PM
acurabum's Avatar
It's a 15 min job . But you have to jack up the car and slice under the rear driver door , look up and you will see them ... unplug hoses and a few 10 mm and replace parts ...
Old May 27, 2009 | 09:25 PM
I've got a 99tl. Parts received
17011-S84-A00 Canister Set
17550-S84-A01 Valve, Vent Shu
I haven't been under the car yet to see but I do see a lot of pipe bibs on the new parts. As for the shut valve, it seems to attach or plug into some other part.
I know its not a big job, but if anyone could let me know were the parts are located and is there any gotchas I need to know. Also, with all the valves in the system, have I got the right parts ?
smartypants.
Old May 28, 2009 | 07:10 PM
acurabum's Avatar
You really have to get under the car and see both parts close to each others,.
Replace one part at the time in order to reconect all hoses back in the right position .
Old May 28, 2009 | 07:14 PM
acurabum's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Take a look at the picture at this link.
Old May 28, 2009 | 07:17 PM
acurabum's Avatar
#8 and #5 ....
The only concern is to remove to 2 rust bolts that hold each part to the under chassis.
Other then that is only remove and install .
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
gqdabien
Sep 8, 2015 11:41 PM
ellisd03tls
Sep 8, 2015 04:17 PM
