D4 light on is blinking/Code 1773
Old Dec 24, 2005 | 01:51 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
my d4 light is blinking and the check engine is on also, when i checked it with the scanner i got a code 1773 for Automatic transmission malfunction great another problem
Old Dec 26, 2005 | 12:13 AM
loud_whispers's Avatar
probably p1730 code or a p1750
incorrect gear ratio.
clutch pressure failure.
check lfuid, check for leaks, if not it's an internal trans. failure and you will need a trans.
Old Dec 26, 2005 | 12:29 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
This is certainly nothing out of the ordinary for a TL.
Old Dec 26, 2005 | 01:02 PM
Skeet Skeet Skeet
already check the code 1773 and its the clutch pressure plate control selonoid valve B which only cost $37 and its on the ouside of the tranny so its not a big deal
Old Dec 27, 2005 | 02:03 PM
fla-tls's Avatar
On the way!
The diagnostic proceedure for that code is 11 steps long and could lead to anything from a bad solenoid, to a wiring harness problem, to a bad PCM.
You could go the "cheap" route and put in the new solenoid - since you know all about it. Just be warned that a new solenoid may not fix that code.
Old Dec 27, 2005 | 07:03 PM
Skeet Skeet Skeet
thanks man i already got it taken care of, it was one of the electrical connecton on the tranny that was loose so plug back it in and reset the check engine light
Old Dec 27, 2005 | 07:38 PM
fla-tls's Avatar
On the way!
Glad you got it covered!
Old Dec 27, 2005 | 07:46 PM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
Nice! you didnt need a new tranny.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
