CPU Reader Problem
Old Oct 16, 2009 | 02:26 PM
Bobdigi22's Avatar
CPU Reader Problem
So I hit the jackpot on my dashboard lights because, CE, TCS and MR light are all on. I went to an autozone to get it read and the cpu reader bracket is broken and it will not connect to the diagnostic machine until I can get it secured. Someone please help out a noob. Thanks in advance. (99 tl)
Old Oct 16, 2009 | 06:08 PM
fsttyms1's Avatar
Well the only thing you can do is remove the center console to get to it and try to reattach it or find a way to.
Old Oct 16, 2009 | 07:21 PM
Rajca's Avatar
wham bam thank you ma'am
my tl has the same problem. i use long needle nose pliers and pull it back into the bracket and then gently plug the scanner in.
Old Oct 20, 2009 | 12:34 PM
6MTUA5's Avatar
No He Can't
You can pull that plastic piece under the coin tray and feel around in there for the OBDII port. Hold onto the back of the gray female connector and plug in the code reader.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
