compression test..need to remove all spark plugs?
Old Jul 24, 2011 | 07:31 PM
smilecow's Avatar
I own a 2003 acura tl.
I want a compression test on the front cylinders only.
Do I still need to remove the spark plugs in rear?
thank you
Old Jul 24, 2011 | 10:20 PM
01tl4tl's Avatar
mind sharing why?
to answer- a good compression test requires the starter to turn the engine at good speed- a consistant speed-
so remove all the plugs AND hook up a battery charger during testing!!
Old Jul 24, 2011 | 10:21 PM
01tl4tl's Avatar
if looking for coolant traces - head gasket prob- water damage should be evident on the plugs-
or if gasket blown, coolant will shoot from spark plug hole
Old Jul 25, 2011 | 01:26 AM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
they tested the compression at the Honda dealership when i bought my car... (brought it to them for a tech to inspect - got the older guy who races and builds cars) said it checked out...
Old Jul 25, 2011 | 10:58 AM
01tl4tl's Avatar
unless its been severely overheated the compression should be fine
for your purpose- pull the fronts and get a basic reading
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
STL TL-S
Sep 23, 2015 08:52 PM
Cexarin
Sep 23, 2015 07:43 PM
