Code 1676 Injector wire signal HELP PLEASE
Old Mar 4, 2008 | 03:37 PM
Mikrobe's Avatar
6th Gear
Hi all love this web site!
Recently my 1999 Acura 3.2 TL has been stallling occasionally when I am in drive I try to restart the car, it turns over and then dies. Other ? symptoms sluggish, fuel economy down . Took it to my mechanic scanned it and came up with code 1676 , it supposedly has to do with a injector wire signal ??? Has anyone had this code or problem before?
Thanks Mike
Old Mar 4, 2008 | 03:43 PM
01tl4tl's Avatar
what did the tech think? codes are NOT diagnosis- just clues
a 99- do you have the cap-rotor-spark plug wires motor?
99s have an ignition switch warranty-call acura at 1-800-382-2238 x5 or go to the dealer
You need the VIN number when you talk to anyone about the car.
the older motor cars also got a free tune up for emissions reasons too- at high miles.
Old Mar 5, 2008 | 10:10 AM
TLer trash's Avatar
Code 1676 is set when there is a signal problem between the pcm and the abs/tcs control unit. I checked the diagnostic procedure, and step 1 is to clear code and see if it returns. If it returns, the next step is to check 2 wires between the components. If they check out ok, it's the pcm or abs control unit. If no code comes back, and you still have running problems, start with the basics like 01tl4tl suggested.
Old Mar 9, 2008 | 05:51 PM
Mikrobe's Avatar
6th Gear
Thanks guys I will try these things before going to the stealer(dealer). Will let you know how things turn out.
Mike
Old Mar 26, 2008 | 09:16 PM
jgallagher392's Avatar
5th Gear
Thanks Mike
Hey my car is having the same problem. my error code is P1676 TCSDL (FPTDR)signal failure. what does this mean and did you ever figure out your problems?
Old Mar 27, 2008 | 08:32 AM
Montaigne's Avatar
2000 TL
"the older motor cars also got a free tune up for emissions reasons too- at high miles"
How does that work? Is that CA only or elsewhere?
TypeS860
Jan 10, 2026 11:11 AM
Mike Pilipenko
Mar 26, 2024 09:21 PM
SUPRMN84
Oct 7, 2015 09:46 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
