Child Door lock broken
Old Jul 22, 2013 | 07:10 PM
jeparkes18's Avatar
6th Gear
I have an 05 tl that I just bought and the rear driver side door won't open from the inside but the child lock switch is stuck in the up position. Has anyone else had this problem and if so how did you fix it? Thanks for any help
Old Jul 22, 2013 | 08:23 PM
HairyMonkey019's Avatar
wrong section, this is the 2g side
Old Jul 23, 2013 | 07:20 AM
3.2TLc's Avatar
But if ya can open it from the outside, ya may be able to force the lock switch's over-ride down.
Do ya need to have the "child door lock over-ride feature" ? If not, just disable it.
Old Jul 23, 2013 | 08:55 PM
jeparkes18's Avatar
6th Gear
Sorry about the wrong section I'm new to the site. And I've tried everything I can think of short of taking the door panel off, including brute strength, to get the switch to budge and nothing. What is the child door lock over-ride feature?
Old Jul 24, 2013 | 07:22 AM
3.2TLc's Avatar
Rear door's child lock switch....
After rereading your post, I realized that the switch is up as it normally should be, but won't allow the door to open when inside. Hmmm...Somebody must have forced the switch up and now it's apparently stuck.
But, whatever is inside the child lock switch mechanism thinks it's in the "down" mode for the switch to be still on. Probably have no choice but to open up the panel and take a closer look at what's binding within the door.
Old Jul 25, 2013 | 12:05 AM
jeparkes18's Avatar
6th Gear
Thanks I was hoping I could avoid that but it seems that is the only real way to figure out why this is happening. I'll probably do that in the next few days and give an update on what it was
Old Aug 6, 2013 | 04:20 PM
3.2TLc's Avatar
Hey Jeparkes18, so how did things turn out ?
What did ya find to be the problem with your rear door not opening ?
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
