Check Engine Light & Hesitation
Old Jul 23, 2006 | 12:07 PM
assassin004's Avatar
8th Gear
I just purchased a used 2002 TL-S and I have had several issues including the transmission recall. Currently I am experiencing hesitation during acceleration and I have the following check engine codes:
P0301
P0302
P0303
P0305
P0306
P1399
I am confused as to what I should do. I have already spent a considerable amount of money replacing the EGR sensor and ECM and am still having performance issues with the vehicle. Can anyone please give me some advice?
Old Jul 23, 2006 | 01:04 PM
Blazin_TL's Avatar
Registered User
01,02,03,05,06 and cylinder misfires.. the 1399 is a random misfire.. check your plugs and coilpacks
Old Jul 23, 2006 | 06:40 PM
8th Gear
Thanks! What should I look for on the plugs (carbon build up?), and the packs (how do I check them)? I have a hard time believing that they all went bad at the same time. How should I check them, what should I look for? Personally, I think that the cause of the problem has to do with something else. What I mean to say is what would cause a malfunction in all but one of my cilenders? I have read about people with the same problems spending money on plugs, cilenders, and O2 sensors with no luck. I just wonder what it is. I have not made any mods yet so what could it be? Basically, my car performed fine for 3 months and then I started it one morning with all the sensors on. The symptoms where very apparent, it shook violently, hesitited, and shifted very tempermentally. So... I replaced the EGR sensor...and then the ECM...and then the transmission. What am I left with...a wierd shifting transmission and occasional hesitation when I accelerate. = all the performance I once had...gone. Sorry for the long reply. PLEASE HELP, ANYONE WITH EXPERIENCE OR KNOWLEGE. PLEASE!!!!
Old Jul 23, 2006 | 09:16 PM
Blazin_TL's Avatar
Registered User
luckily i have experience with coil packs.. i don't know much about spark plugs. but i know only 1 bad coilpack can cause multiple misifires. does it feel like the engine is shaking during idle?
Old Jul 25, 2006 | 06:35 AM
8th Gear
It feels like the engine is running a little rough, I can feel a slight shake. Also, there is a slight hesitation at times (mostly unpredictable) during acceleration. How can I check if a coil pack is bad? Also do you think I should go to the "stealer" to check it out or should I just replace the parts myself and see what happens? I have paid for this problem before, do you think there is any chance the stealer will cover it or at least check it for free? Please advise.
Old Jul 25, 2006 | 01:55 PM
fsttyms1's Avatar
With that many misfire codes i would check into a 02 sensor as a possible issue
Old Jul 25, 2006 | 02:18 PM
Blazin_TL's Avatar
Registered User
wouldn't the 02 sensor throw its own code?
Old Jul 25, 2006 | 02:29 PM
fsttyms1's Avatar
sometimes. Other members have had it cause 6 missfirecodes
Old Aug 8, 2006 | 02:35 AM
Johnnovember's Avatar
8th Gear
My car has hesitation ( unpredicatable) at times. It doesnt say check engine tho. it has 83k
2002 tl type s, never replaced anyting except trans, pads and oil. Brought it to the dealer and they said im nuts, although they did replace my f*ing engine mount for the 3rd time this year
Old Mar 13, 2007 | 01:36 AM
Soseductivesf's Avatar
Are coil packs under warranty?
Old Mar 13, 2007 | 01:51 PM
gooddfella's Avatar
Just buy one and try them one by one and you'll get to the right one. I did it today and it worked.
Old Mar 13, 2007 | 03:50 PM
01tl4tl's Avatar
Codes are not diagnosis of problems
They must be taken as a series of clues leading to the real problem
My car said it had engine over-rev- but in reality it had a slipping trans!
Everyone should read the Gen2 thread titled Seafoamed the Ol TL
and you will run out- do it, and expereice better running engine.
Old Mar 13, 2007 | 03:52 PM
01tl4tl's Avatar
Assasin
When you say trans recall, do you mean you took it in for the free oil jet kit install
or you had the trans replaced under factory extended warranty?
Who diagnosed and replaced the other parts
Old Mar 28, 2007 | 03:51 AM
freeuser209's Avatar
im having the same problem i have 03 type s car kinda shaky at low rpms n on the freeway im gettin po300 Po301 Po304 Po305 codes ..i switched around the coils today to see if its spark plugs or coils n reset the ecu check light n vsa light went away n hasnt came back on yet..
Old May 3, 2014 | 01:19 PM
doggydog's Avatar
....Same codes but on 2006 TL.... posted in 2007 really....people please update when you are having problems.
Old May 3, 2014 | 02:19 PM
TLZINE99's Avatar
id recommend doing this test for cylinder misfires.
Old May 3, 2014 | 03:05 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Pause!
Since you just got the car clear the codes to start of fresh and don't replace any parts until you have a full diagnosis of whats going.
More than likely those misfire codes are being set because of clogged egr passages or a bad coil. Try the power balance test provided above.
Old May 3, 2014 | 03:41 PM
doggydog's Avatar
Great video, thanks guys.
Before I go out and try this, I did get a random misfire diagnostic ar a shop. P0300,0301,po302,p0304 and po305. In the video he simulated a faulty injector. My question is how do you determine if indeed it is a bad coil pack or a faulty injector. @$76 a coil pack I want to make sure, thanks all.
Old May 3, 2014 | 09:16 PM
fsttyms1's Avatar
Our cars are notorious for throwing multiple misfire codes for just one coil pack. If unplugging them one at a time doesnt show the faulty one, buy one new one, pic a cyl to put it on, install it reset the ecu and take it for a drive. Does the check engine light come back on? If yes repeat the process with the next cyl (taking the new one off and replacing it with the one you took off) and repeat this process. Usually you will find its just one cyl causing the issue.
Old May 4, 2014 | 03:25 AM
3.2TLc's Avatar
Wink Update....?
Hey Doggydog, if no one has bothered to update this ancient thread, don't hold your breath.
For better response, try the 3rd Gen Forum '04>'08.
Old Jun 1, 2014 | 11:48 AM
doggydog's Avatar
Thanks gents and fsttyms1 I will try that , thanks.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
