Check engine light after pumping gas
Old Jul 27, 2009 | 11:09 AM
Michael Bach's Avatar
7th Gear
HI
I'm new to this forum.
I just purchased a 2002 TL. I let it sit for a week while selling my prev car. So after the week I drove it later one night to get gas and pumped the premium gas with the Acura engine running. (I never do this but I wanted to charge the battery as it's old). I didn't drive it for another week and have now been driving it for 4 days. When I started driving it 4 days ago the check engine light was on. It wasn't before. I read the manual and noted this occurs if the gas cap isn't twisted at least 3 times. I figured I didn't do this and twisted it a few times but it remains on. The manual says it can take 3 trips to turn off but I've driven the car about 8 separate times the last 4 days for a total of maybe 25 miles. So my quesition is: how long does it take for the light to go out if one pumps gas with the car running and doesn't tightern the gas cap and then lets it sit for a week, i.e. should I take it to the dealer now or wait a little longer to see if it goes away?
Mike
Old Jul 27, 2009 | 11:38 AM
SG81's Avatar
Missing My CL-S
Reset the ECU and see if it comes back on. If it does come back on, get the code read and see what it is.
And Welcome the Acurazine!
Old Jul 27, 2009 | 06:50 PM
7th Gear
Code is 1457 and the EVAP Bypass Solenoid is bad. I wonder if it could cause any damage to run it like this for a few weeks
Old Jul 27, 2009 | 09:12 PM
hANDYcaptd's Avatar
It's the Halladay season!
It shouldn't cause any more damage. Members here have ran for years with a bad EVAP canister.
Do you notice a constant clicking noise under the driver side rear door?
Old Jul 27, 2009 | 10:19 PM
miamirice's Avatar
Yup
Originally Posted by SG81
Reset the ECU...
just in case you don't know how to do this...disconnect and re-connect the negative terminal on your battery.
Old Jul 28, 2009 | 08:02 AM
fsttyms1's Avatar
Like the others said,go and pull the clock back up fuse #13 on the passenger side fuse panel for a min to reset the ECU and see if it comes back on
Old Jul 28, 2009 | 09:28 AM
7th Gear
Thanks all for the help. There's no clicking. The solenoid was hooked directly to power and it isn't working. I understand a bad EVAP Bypass solenoid is a common problem. I just hope its the only problem. I believe I can hold off awhile given I have higher priorities right now till I can replace it.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
