check engine light
Old Feb 11, 2010 | 10:18 PM
Mikaveli54's Avatar
2003 Acura TL-S
check engine light
I have a '03 tl-s with 143k miles. I changed the timing belt, water pump, and spark plugs about 130k. My check engine light has been coming on along with the traction control light and the ABS light. I took my car to the local mechanic and ran a diagnostic and came back with 'multiple cylinders mis-fire'. My question for yall is where do I start???? and with the mileage that I have, what should I do to keep up with the maintaince?
Old Feb 12, 2010 | 11:46 PM
dsalazar1's Avatar
Try to diagnose were the missfire is coming from. Can you hear or feel the missfire? Try some seafoam.
Old Feb 13, 2010 | 09:19 AM
fsttyms1's Avatar
Typical random misfire is usually 1 coil pack. Most have great success buying 1 new coil pack and starting on cyl #1 and replacing the coil pack, reset the ECU and drive the car. IF the check engine light comes on Take off the new coil pack put the one that was on that cyl back on and go to #2 and repeat. You repeat till you find the coil pack that is causing the problem. Also make sure your spark plugs are all tight.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
