ticking noise when stopped
Old Jan 8, 2010 | 09:49 PM
lex513's Avatar
Exclamation ticking noise when stopped
Hello i have a 1999 aura tl with 118k it is a very good running car but i have a few questions about 2 months ago i heard a werid noise when i was stopped coming from i think the left side of the car and it was like a ticking or light clicking noise like a consisted noise and when you release the break it stopped it dosent do this much but i can feel when it dose do this?? Can i get some help!!?
I also have been feeling uncomfortable about my tanny becuz after 2nd or 3rd it seems to take a little longer then normal and the transmission dip stick is hard to read on these cars some times it is at the right spot and others it looks like it needs some..??
Old Jan 8, 2010 | 10:57 PM
fsttyms1's Avatar
The ticking engine compt or by the drivers side rear wheel? Either are normal and only need to be fixed if it bothers you.
When was the last time you changed the fluid?
Old Jan 8, 2010 | 11:07 PM
totaledTL's Avatar
Are you checking the fluid the same way each time, and as the o/m advises?
Old Jan 26, 2010 | 01:21 PM
smartypants's Avatar
Hi Lex :
I also have a 99 and it has ticked for the last five years. It seems to get worse in the cold and when the oil gets low. Years ago, I took it to the dealer and they said it was a common problem that was related to the fuel injectors and it was not an indication of a pending failure, just noisy.
I've also heard that most Honda engines tick for a variety of reasons. I'm not concerned anymore cause if it ever causes a serious problem, I'll simply tow it to the bone yard.
Sad but true
smartypants.
Old Feb 1, 2010 | 10:39 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
As totaledTL eluded to, you should check your tranny fluid when the car is warm and has been driven for awhile; you can even check it with the engine still running. The reason for this is that much of the tranny fluid is in the torque converter during operation, and when you turn the car off, that fluid drains from the tc into the pan, causing the level to rise, and the dipstick reading to be higher. The markings on the dipstick are calibrated to be checked during, or right after, normal operation of the tranny (i.e., with tc still filled up), so that is when the fluid level should be checked.
Old Feb 2, 2010 | 07:44 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I have owned 3 Honda Products. The engine in each has always been more noisy in the winter times. Injectors tick etc. When it warms up again/all will be quiet if everything is in working order.
Old Feb 14, 2010 | 01:18 PM
jdjohn84's Avatar
I have had a ticking sound as well, and it sounds like it is right behind the gauges, just on the other side of the firewall...and it is. It is the EVAP canister purge valve, and it looks like this.
It's in the middle of the pic, to the left of the fuse/relay box, and behind the brake fluid resorvior. If you hear ticking from this area, it is probably coming from that.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
