Change 02 when changing Cat ?
Old Dec 28, 2006 | 11:17 PM
zryde's Avatar
Is it usually necessary to change the 02 sensor when you are having the Catalytic Converter replaced?
Old Dec 28, 2006 | 11:56 PM
acutee's Avatar
No, you don't need to change the o2; unless the o2 is malfunction.
Old Dec 29, 2006 | 10:00 AM
ArN 2000 TL's Avatar
Moderator Alumnus
how many miles do you have that your changing your cat?
Old Dec 29, 2006 | 11:27 AM
zryde's Avatar
160,000 miles and counting
I got the P0420 code with the CEL coming on intermittently, and now it stays on
Old Dec 29, 2006 | 04:00 PM
Moderator Alumnus
nice. I just hit 101k and was wondering how long they would last. The car feels a little sluggish sometimes an i wonder if it is related to that. I already changed the plugs, cleaned the intake manifold and ran seafoam through everything 2k miles ago. Car has never thrown any codes yet.
Old Dec 29, 2006 | 10:11 PM
zryde's Avatar
Cat problems can definitely make a car sluggish
My buddy had a mechanical tell him the cat was the problem with an impala that had 125K and no check engine light?????? it fixed it
My check engine light would come on and the car would immediately feel sluggish and/or constipated, it would go off and ride better.
I got tired of it and changed the cat, hopefully the CEL goes off soon.....
Old Jan 4, 2007 | 07:00 PM
mdavisii's Avatar
B93P TL Owner
My cat lasted approximately 100,000 miles, just barely missed the 80k mile federal warranty. As for my O2 sensors, I am still on my original ones at 170,000 miles without any signs of trouble. Don't understand how some manufacturers recommend changing them things so often, it seems like they last a lifetime on these cars.
Old Jan 7, 2007 | 02:08 PM
zboys's Avatar
99 TL
Resetting P0420 code afetr replacing cat?
I just replaced my cat with a Random Technology high flow cat (183-20002). My 99 TL started giving me a P0420 code at 88K miles but I just replaced the cat at 155K. Should I reset the P0420 code with my scanner or let it clear itself?
Old Mar 19, 2007 | 10:34 PM
Brewgod23's Avatar
I got my CEL with P0420 code. How can I reset the OBD code without a scanner?
Old Mar 20, 2007 | 07:44 AM
fsttyms1's Avatar
Pull the Clock backup fuse on the passenger side dash fuse panel for 10 min.
Old Apr 9, 2012 | 04:21 PM
DaHadster's Avatar
I was told that a scanner shows when a system was reset - that's why I needed to drive 40 miles after a reset before taking her back to the emissions inspection. Does this 10 min fuse trick show a reset on the scanner?
Old Apr 9, 2012 | 04:27 PM
fsttyms1's Avatar
Yes, that is only to erase codes and the CEL. Testing equip will show that the ecu was reset and if it doesnt meet the requirements they will fail you and tell you to come back.
Old Apr 9, 2012 | 04:47 PM
Skirmich's Avatar
196K = OEM CAT, OEM 02 Sensors... Pass Emission Tests with flying colors...
Old Apr 9, 2012 | 05:17 PM
01tl4tl's Avatar
I just wrote about the special driving procedure in another thread- for after ecu reset and headed for smog test
Need to run the engine thru every condition,,not just cruise around 40 minutes and think its recorded enough data for inspection
most of us are going with `1 minute` of clock fuse removal will clear and reset the ecu
You can disconnect the battery neg cable instead but that requires radio code input,,
while clock fuse is the secret backup power to ecu and doesnt affect radio `security`
(disconnect batt and radio thinks its being stolen)
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
