CEL problem
Registered User
CEL problem
ok from a dead stop i hit the gas to WOT and at around 4k+ rpms the car started to shudder a lil bit almost like a misfire.. cel started blinking.. i smelt a lil burning but as soon as i stopped the cel went away... is there anyway i can find out what that code was? if i plug in the obd will the code be pending ? what could this be? thanks for help
Originally Posted by 03CoupeV6
That's definitely a misfire. To my knowledge, the OBDII stores codes even when the light is not on.
Yes, I do believe you are correct. And yeah, thats definately a misfire. I had that problem in my infiniti, and it turned out to be a bad coil.
Registered User
so what do u think it could be? the car drives fine, only in first gear at WOT it misfires.. do you think i have a bad plug? i dont think it could be a coil because it would be misfiring at idle also...
Registered User
another update... it misfired again today and made kind of a pop noise.. kinda like a a backfire noise just much lower.. it also misfired when i turned on the car.. i got my codes pulled and i got an p0300 301 302 303 305 & 306 .. i have a feeling my spark plugs are bad
I'm going to pull the Check Engine Light codes on my sister's 2002 3.2TL but can't find the Actron's OBDII plugin port for that model. The ports on my Mercedes Benz E-class and SLK are at the driver side, under the steering wheel column.
Thanks,
Netdvn
Thanks,
Netdvn
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
