CEL problem
Old Mar 6, 2006 | 04:52 PM
Blazin_TL's Avatar
Registered User
CEL problem
ok from a dead stop i hit the gas to WOT and at around 4k+ rpms the car started to shudder a lil bit almost like a misfire.. cel started blinking.. i smelt a lil burning but as soon as i stopped the cel went away... is there anyway i can find out what that code was? if i plug in the obd will the code be pending ? what could this be? thanks for help
Old Mar 6, 2006 | 05:21 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
That's definitely a misfire. To my knowledge, the OBDII stores codes even when the light is not on.
Old Mar 6, 2006 | 06:02 PM
Comet2404's Avatar
Flyin' and Drivin'
Yes, I do believe you are correct. And yeah, thats definately a misfire. I had that problem in my infiniti, and it turned out to be a bad coil.
Old Mar 6, 2006 | 10:54 PM
Blazin_TL's Avatar
Registered User
so what do u think it could be? the car drives fine, only in first gear at WOT it misfires.. do you think i have a bad plug? i dont think it could be a coil because it would be misfiring at idle also...
Old Mar 7, 2006 | 07:54 AM
03CoupeV6's Avatar
It's probably a bad coilpack. It doesn't misfire at idle because there's no load.
Old Mar 9, 2006 | 11:54 PM
Blazin_TL's Avatar
Registered User
a little update.. another coil actually went out, i replaced it today and its still happening...
Old Mar 10, 2006 | 09:40 AM
fsttyms1's Avatar
How do you know it was the right coil pack you replaced? Have you replaced your plugs at all?
Old Mar 10, 2006 | 11:41 AM
Blazin_TL's Avatar
Registered User
i definately know i changed the right coil becuase my car dosent shake like crazy anymore.. i changed my plugs about 10k miles ago
Old Mar 10, 2006 | 11:48 PM
Blazin_TL's Avatar
Registered User
another update... it misfired again today and made kind of a pop noise.. kinda like a a backfire noise just much lower.. it also misfired when i turned on the car.. i got my codes pulled and i got an p0300 301 302 303 305 & 306 .. i have a feeling my spark plugs are bad
Old Mar 11, 2006 | 02:12 AM
fsttyms1's Avatar
I would start out by replacing them (cheapest route) what kind of plugs do you have in?
Other wise it may very well be a O2 sensor causing it
Old Mar 12, 2006 | 12:35 AM
Blazin_TL's Avatar
Registered User
if my o2 sensor was bad woulnt it have its own independant code on the OBD?
Old Jul 9, 2006 | 08:40 AM
netdvn's Avatar
I'm going to pull the Check Engine Light codes on my sister's 2002 3.2TL but can't find the Actron's OBDII plugin port for that model. The ports on my Mercedes Benz E-class and SLK are at the driver side, under the steering wheel column.
Thanks,
Netdvn
Old Jul 9, 2006 | 01:32 PM
Blazin_TL's Avatar
Registered User
its behind the shifter.. pull the plastic piece back
Old Jul 9, 2006 | 02:48 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
yup below the "not an ashtray" tray in the back of the little pocket. it pops right out
Old Jul 9, 2006 | 03:36 PM
PenancE's Avatar
change ur plugs too...they must be bad,
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
