Catastrophic Coil Failure
Old Apr 6, 2008 | 03:09 PM
Sundance Kid_69's Avatar
'02 TL-S w/Navi
I have a ’02 TL-S w/ 140k. I nearly never post since I find most of my answers in the forums. However, I have not been able to find anything on this. I am going back a few months with this to give it some background. The symptoms seem to be so similar that I feel it may be important. Symptom: the car will start to run rough and give me random misfire codes. First time it was a coil, no problem. Second time, it was the cat; still no problem. Third time (two weeks ago) it was another coil and I started getting annoyed. This time, the car started running rough, I ordered the coil and decided to do plugs as well, but I never made it home. She died on me altogether. I had it towed home, since I already had the parts coming. I found the new coil (two weeks old) was melted into the socket! Thus the catastrophic header above. It took five hours to get the thing out of the socket. I replaced that coil and all the plugs, but it will not start. It doesn’t even feel like it’s trying hard. I can’t figure it out. I did a hard reset, removed the battery terminals for a bit, to reset the computer and when that didn’t work came here to find out which fuse I was suppose to pull thinking there may be some residual. Still nothing. The original five codes were Cylinder 1,3,4, and 6 misfire and random misfire. No new codes are appearing... Sorry for the book. Any thoughts?
Old Apr 6, 2008 | 07:37 PM
fsttyms1's Avatar
So the car wont turn over easy now or it turns over normal, just doesnt want to start
Old Apr 6, 2008 | 08:56 PM
'02 TL-S w/Navi
Turns over fine. I smell fuel in the exhaust, I assume that rules out fuel pump. I just swapped out two of the coils to see what happens. It sounded a little different. I ordered two more coils. Anyone know how to test them. I assume I shouldn't put my tongue to it.
Old Apr 6, 2008 | 09:02 PM
fsttyms1's Avatar
Have you pulled the plugs or changed them?
Old Apr 6, 2008 | 09:28 PM
'02 TL-S w/Navi
Replaced all six. NGK Iridiums...
Old Apr 9, 2008 | 12:11 PM
'02 TL-S w/Navi
Where's the computer for this system? Anyone?
Old Apr 9, 2008 | 04:16 PM
fsttyms1's Avatar
The ECU is located behind the center console near the firewall. Why??
Old Apr 9, 2008 | 08:58 PM
'02 TL-S w/Navi
I pulled it just to see if I could find any obvious problems. I replaced all the coils now. Still nothing. I'm ready to give up...
Old Apr 10, 2008 | 08:30 PM
MotionEffects's Avatar
Acura TLS are SLOW
did you check Fuse 11 in the drivers panel?
Old Apr 12, 2008 | 11:15 AM
'02 TL-S w/Navi
Fuse 11 huh?
I'll try it...
'02 TL-S w/Navi
I tried all the fuses under the hood
Old Apr 12, 2008 | 12:02 PM
01tl4tl's Avatar
Fuse number 12 iirc- in the passenger footwell area is marked Clock but is really the secret backup power to the ECU - Engine Control Unit- engine computerish something and pulling its power supply will force a reset
Thats what you do when you install a crank pulley and certain other engine related mods so the computer learns the change-
Old Apr 13, 2008 | 12:01 AM
Acura TLS are SLOW
fuse 11 is located in the Driver's dash panel.(says wiring diagram) The fuse is for the coils. Let me look at the wiring diagram to see if there is anything else. Is something clogged in the air filter? did you check for fuel? fuel pump bad?
Old Apr 13, 2008 | 01:40 PM
'02 TL-S w/Navi
Red face
And the winner is... Fuse # 11!!
Serves me right for assuming all the engine control fuses would be in the engine compartment.
What a dope.
I should have started simpler.
Thanks for the help.
Off to Seafoam...
Old Apr 13, 2008 | 01:45 PM
Acura TLS are SLOW
Old Apr 13, 2008 | 05:35 PM
Manapuaman's Avatar
Nighthawk Black Pearl
What a dope.
Off to Seafoam...
That is awesome! This is why I love this Acurazine!!! Everyone willing to help others out with their problems. Thank you all. Im buying
Old Apr 14, 2008 | 05:32 PM
Acura TLS are SLOW
Man!!! I hate this community.....................jk
Jamus22
Jun 11, 2023 10:08 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
