Car Vibrates...at 85+
my car TL-P 65K...03 model.....
am visitin my friends in canada..so this was my frist big trip after i bought the car used..at 59K. While driving i noticed strong vibration at 90+...pedal and the steering wheel....as if the car's on a vibrator.
as soon as i slow down...it stops...does anyone know wat mite the problem would be??..two days after am goin back to NY..so i wud try to look for the problem if described.
btw i just installed them yokohamas V4s....superb tires...thanks all u guys.
and if u canada users could also recommend places to visit...in toronto!!
Originally Posted by pmptx
or the wheel balance is off slightly
maybe a rebalance in needed on all 4
just got news tires..and did the alignment..!! FRONT AND REAR..
and isnt it standard to balance them when u mount new tires??
and i think that guy did that...
I had the same problem on an 01 CLS that I had. It would vibrate at high speeds, and everything would shake. I thought it was the rotors, but they were fine. However when I did take it to acura, they said that it was possibly that the brake pads where sitting on a very slight angle on the rotor. they said that this could be the cause, I didnt fix it because my car was hit for the third time in a year and i decided to trade it in for an 04 TL. Hope this helps
Its possible the tires arent balanced properly. Id bring it in and tell them your getting a vibration and would like the tires checked for balance
Check your tire pressure as well. I had vibrations for a few days going 65+ and I noticed the tire pressures weren't matched upped. Pumped up my tires and everything was fine.
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
My tire pressure is +3PSI of the recommended pressure in all 4 tires.
and ye two front tires are yokohama and two rear tires are OEM michelins.
would that setup make my car vibrate?
and for the balancing the tires...
i juss looked at the tires and thos pins are removed...(balancing pins)
so i think he balanced it.....any other ideas?? or its just a matter of rebalancing.??
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
so i think he balanced it.....any other ideas?? or its just a matter of rebalancing.??![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
darshan_patel
any news ...
I am having same problem on 60mph. Funny think - that happens only from 55 to 65 mph (at 60 is a peak). At these speeds I feet around steering wheel shake (around 1/2 inches).
And I believe it start happening after Acura dealer accidentally broke my front tire, and both front tires was replaced to a brand new (can’t recall brand now). So I believe (hope
) the tires was balanced. Or new tires need to be rebalanced in short time after first installation?
May be anyone know what this can be?
any news ...
Originally Posted by mmaaxx
darshan_patel
any news ...
any news ...
Wheels was rebalanced and that fixed the problem. So means first time they was not balanced or was not balanced properly. Shame on them! (official Acura dealer and service center in Rochester).
Legend2TL
Motorsports News
01-31-2016 09:27 AM
