Car shut off while running
Old Feb 5, 2009 | 03:24 PM
gregarch99's Avatar
About two weeks ago and then again the other day my 99 3.2TL shut off while running. Luckily, I wasn't in traffic either time and slowly stopped on the side of the road and it started back up right away with no problem. Does anyone know what might be the cause of this and what I can do to fix it? Since it's starting back up it doesn't seem to be a big issue but I can only imagine something isn't going quite right and it may get worse.
A little background if needed: There's about 159,000 miles on it, had the timing belt along with all the other belts changed exactly 1 year ago (I've put 16,000 miles on the car since then).
Thanks for any help!!!
Old Feb 5, 2009 | 06:42 PM
fsttyms1's Avatar
Sounds like an ignition switch. There is a problem on the 99s and they were recalled. See if yours has been replaced, if not get it replaced. If it has been many have had the replacement fail and needed a new one.
Old Feb 5, 2009 | 10:49 PM
Bob_F's Avatar
:Agree:
If it's already been replaced under the recall, you can buy one yourself for about $50. There's a great DIY linked in the DIY Thread.
My 1999 TL is on its third ignition switch.
Old Feb 6, 2009 | 12:21 PM
01tl4tl's Avatar
As soon as I saw the thread title-- my brain said its a 99 right?!
Call acura with your VIN and ask if the recall was performed
1-800-382-2238x5
If no- get it in right away- call for appt at local dealer as they may have to order it
if yes- go to the parts store and buy one as bob and kris have said- the DIY section is your friend
Old Feb 7, 2009 | 09:37 PM
gregarch99's Avatar
Ah, the ignition switch. Last year when the timing belt was messing up I looked into the ignition switch myself as a way to trouble shoot. At that point we didn't know the timing belt lost it's tension (luckily it didn't break, phew). I can't recall now whether we changed the switch or just tested it, I think just tested it so I'll go ahead and replace it myself and see if that doesn't solve the problem. Thanks for the help!
Old Feb 7, 2009 | 10:20 PM
01tl4tl's Avatar
See if the switch has been changed
If not- call acura and see if its a freebie for you- get that recall when its available to you!
Old Feb 8, 2009 | 11:22 PM
slavver01's Avatar
03 ABP tls
sounds like ignition switch.... my 99 tl had the dealer replace it and i had to do it again when it started shutting off on me
Old Feb 9, 2009 | 08:51 AM
mark07's Avatar
i have the same problem. mine does it very quick tho. i can see the on odometer that my spped indicater goes down along with the gas and everything but this happens only for a sec. i have a 02 is it prob the same iggnition switch??
Old Feb 9, 2009 | 09:50 AM
cyde7399's Avatar
i would suggest just taking it in to acura and having them do it. When i brought my 99 in, they did some other recall to the ignition system as well. It was something like the ignition contacts.
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Phambam12
Sep 6, 2015 06:57 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
