Car idling hard...trouble starting
Old Sep 9, 2007 | 02:10 AM
JetBlackAC's Avatar
I just got home from a night on the town and I noticed when I was at the light my car starting idling really hard, almost cutting off at the light. I drove home the last 3 miles and the engine was making a very loud sound. I got home and tried to turn the car back on and it acted like it didnt want to start. When it did finally start it was still running funny, and the fan was cutting on. Is it just overheating, or something more?
Old Sep 9, 2007 | 05:54 AM
01tl4tl's Avatar
Was it overheating- guage more than halfway on the temp?
Check the engine oil level and condition
The cooling fan (driver side fan) runs at odd times- and should not run more than a few minutes after engine shut down
Could be an idle control valve- they get dirty
Old Sep 9, 2007 | 07:33 AM
JetBlackAC's Avatar
didnt seem to be overheating according to the gauge. it does run for a few minutes after I turn the car off, most of the time when its very warm out.
Old Sep 9, 2007 | 09:00 AM
JetBlackAC's Avatar
update....i just went outside to turn the car on to go to the store..not even turning on now. checked the oil level, was a little low, but still should turn on imo
Old Sep 9, 2007 | 10:21 AM
01tl4tl's Avatar
It should not be low- mine barely uses a drop between changes- how is the smell and color of the oil- has it been cooked?
The next obvious thing is- have you replaced the battery yet
Gen 2s are all on the age limit of the OE battery
Take it out and a parts store will charge it up and test for you- free
Also have the alternator tested after the battery is charged
Simple test done for free at parts store
Old Sep 9, 2007 | 10:25 AM
JetBlackAC's Avatar
I replaced the battery last November from the original. The smell seems strange, color is lighter than normal. I cant get any test done because the car wont start.
Old Sep 9, 2007 | 10:38 AM
fsttyms1's Avatar
does it even crank over?
Old Sep 9, 2007 | 10:44 AM
JetBlackAC's Avatar
i added a video to show what it does...
http://www.brightcove.com/channel.jsp?channel=932521996
Old Sep 9, 2007 | 03:26 PM
JetBlackAC's Avatar
any other ideas on this?
Old Sep 9, 2007 | 03:33 PM
01tl4tl's Avatar
Give it a chance- nice weather on a sunday finds many ziners out enjoying their ride or family obligations
By night many will return to the nest and answers will appear
Didnt look at the vid- can you call a friend for ride to parts store so they can charge the battery up for you and test it?
Old Sep 9, 2007 | 03:41 PM
JetBlackAC's Avatar
the battery isnt the issue i dont believe...had the neighbor give me a jump
Old Sep 9, 2007 | 05:32 PM
6MTUA5's Avatar
No He Can't
It may be the fuel pump
Getting spark, just not enough fuel to the motor??
Mine actually did this about 5 minutes ago as I was leaving Zaxby's. Went to start and it did that, but then tried again right after and it started right up. I have also been having problems of it cutting off while driving but starting itself before I even roll to a stop. I have been thinking it is the fuel pump for a while now as I have a new battery and starter.
Old Sep 9, 2007 | 05:56 PM
JetBlackAC's Avatar
I just went out to try to crank it up just now and it started up but still doesnt sound right. Im taking it directly to the dealer Monday morning, will keep you updated
Old Sep 10, 2007 | 07:11 AM
JetBlackAC's Avatar
update -
Not good news. The dealer was swamped with cars this morning, and said the earliest he could get someone to look at the car would be sometime late Tuesday afternoon. From what I described, he thinks its a transmission and possible alternator issue. No loaner cars available either...
Old Sep 10, 2007 | 10:57 AM
01tl4tl's Avatar
When your friend got it jump started- after driving would it restart?
Thats the easy test of the alternator- it should recharge the battery
Not unusual if the battery was dying to take the alternator with it
register here by your VIN https://www.ahm-ownerlink.com/login.asp?brand=acura
and make sure you are covered on the 7/109 trans warranty
If so- breathe easy- its free
If not- we can help you get coverage- those transmissions are worth 4 grand installed!!!
Old Sep 10, 2007 | 10:59 AM
01tl4tl's Avatar
Note- Monday drop-offs
Shop meeting is held for an hour or so- creating a backup of cars
Customers in for service get dibs on the loaners
Once your car is diagnosed- they will find a loaner for you
Old Sep 10, 2007 | 02:47 PM
fsttyms1's Avatar
well going off the video, its NOT trans or alt related. The car cranks just doesnt fire or run.
when you get it running what happens if you floor it.
Also forgot to ask, is there a Check Engine Light?
Old Sep 10, 2007 | 02:53 PM
JetBlackAC's Avatar
Thanks for all the advice!
My car is covered under the recall of the tranny. My car did restart and I actually drove it to work this morning. Im dropping the car off this thursday am. One question, for those that have taken their cars to get a free diagnostic(autozone) would anything about the tranny come up on their codes?
Old Sep 10, 2007 | 02:54 PM
JetBlackAC's Avatar
well that day when i floored it it cut off...today its run ok. at least to work and back
JetBlackAC's Avatar
no check engine light just the maint. req light
Old Sep 10, 2007 | 03:05 PM
6MTUA5's Avatar
No He Can't
You know how to reset that, right??
Hold Select and Reset buttons and turn the key two clicks and continue holding the two buttons til the light goes out.
Old Sep 10, 2007 | 03:13 PM
01tl4tl's Avatar
there are 2 totally different things- the recall was to install an external oil jet kit
The other one is extended warranty to 7 years 109k miles
Mid 03 they made a cutoff date by vin for purpose of the lawsuit- not that it was fixed by then
Old Sep 11, 2007 | 06:37 AM
JetBlackAC's Avatar
thanks
Old Sep 17, 2007 | 09:55 PM
acuratech25's Avatar
have you ever replaced the main relay that could be a possibility
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Mike Bertram
Sep 10, 2015 09:27 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:14 PM
