Can't remove the Comptech Icebox Lid
Old Apr 11, 2007 | 10:27 PM
randomthought's Avatar
rebmeM deretsigeR
As in the title, I can't remove the damn thing. From what I can tell, the bolt between the box and the headlight is turning, but the piece that it connects into is turning along with it. Anyone know of a way to remove the lid without cutting the bolt or removing a section of the lid itself?
I am trying to remove it because I just Sea Foamed my car and a LOT of the stuff ran out through the throttle body and through the filter, ending up on the ground. Runs better now with o sticky gas pedal, but paranoid with so much sea foam going through the filter.
Old Apr 12, 2007 | 11:56 AM
drcookie's Avatar
Well, I have the same issue after I left the car for dealer to swap the tranny. I did not realize at the time until I was changing my oil (I service my air filter at the same time) and I can't remove the bolt. I ended up has to destroy it by prying the box out with the bolt and screw in it. You would see a cavity on the box. I replace the both with a regular sharp point screw which I could screw directly to the box. I already have two broken ones and so far, they are holding the cover without any issue.
Hope this helps.
Old Apr 12, 2007 | 09:54 PM
rebmeM deretsigeR
I pretty much thought that I would have to do this. I didn't want to take apart my bumper and head light to get to it, but it seems that destroying the bolt is my only option. Thanks for the help.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
