Cant find part# for front engine mount
Does anyone have BOTH part numbers/brands for a good pair of front AND rear, vacuum assisted engine mounts? I have searched and can only find the rears... I think.
I know its been asked alot, so I apologize for being redundant.
i want to replace both my front and rear, what do I do? I have all the other mountsx ready to go. just need the front and rear big boys
acura oem part number for 2002 TLS rear 50810-S0K-A81 and the front is 50800-S0K-A82. Should be able to get what you need from there. Interestingly the acura oem parts did not have the front TL mount listed so I stole it from the CL section as the rear mounts are the same and I would expect the front to be as well.
Those OEM parts should cross reference to aftermarket parts. How many miles on your car and what year is it and trim?
02 CL-S here and my mounts are on the way out at 110K miles
On a diagram for TL it shows front and rear mount as same part. Plus my front and rear mount are exactly the same too. Maybe the different # is for the direction the vacuum line comes out the bottom??
Hmm... I see what you mean in the diagram. Thanks man!!!Can you see on yours if the vacuum line is in the same place??? Is there an aftermarket brand that you recommend? Rockauto.com has DEA, Beck/Arnley...
Well I installed aftermarket mounts from XLR8. They are a solid mount no vacuum assist. The fact that I'm set forever on motor mounts is cool. There's some vibration at idle you can feel after the install but it fades considerably. It will never be as smooth (at idle) as factory mounts but they not gonna brake and make me go through another install so the shaking is a fine trade off.
