Cant find part# for front engine mount
Old Jul 3, 2012 | 09:33 PM
pdxtls6875's Avatar
Does anyone have BOTH part numbers/brands for a good pair of front AND rear, vacuum assisted engine mounts? I have searched and can only find the rears... I think.
I know its been asked alot, so I apologize for being redundant.
Old Jul 3, 2012 | 10:46 PM
MilwaukeeDave's Avatar
Front and rear are same part.
Old Jul 4, 2012 | 02:22 AM
01tl4tl's Avatar
go to one of our sponsoring Vendor-dealers
who cut us a price break and make sure we get the correct parts for our year
Old Jul 4, 2012 | 10:37 AM
pdxtls6875's Avatar
thats not the ino i am finding. where did you see that?
Old Jul 4, 2012 | 10:40 AM
pdxtls6875's Avatar
I called rockauto, and they dont have a part # for a front vacuum assisted mount. They dont offer one. I know these moints go all the time, and OEM is just junk. So if
i want to replace both my front and rear, what do I do? I have all the other mountsx ready to go. just need the front and rear big boys
Old Jul 4, 2012 | 12:39 PM
YeuEmMaiMai's Avatar
acura oem part number for 2002 TLS rear 50810-S0K-A81 and the front is 50800-S0K-A82. Should be able to get what you need from there. Interestingly the acura oem parts did not have the front TL mount listed so I stole it from the CL section as the rear mounts are the same and I would expect the front to be as well.
Those OEM parts should cross reference to aftermarket parts. How many miles on your car and what year is it and trim?
02 CL-S here and my mounts are on the way out at 110K miles
Old Jul 4, 2012 | 01:17 PM
pdxtls6875's Avatar
I have an 03 TL-S NBP with 156k. I'm trying to go aftermarket due to the OEM one being junk.
Old Jul 4, 2012 | 02:24 PM
^If your mounts lasted 153K I would say that they are NOT junk..... the type S is a relatively powerful package in a small size and considering that the front mount takes the most abuse, you did well.....
Old Jul 4, 2012 | 02:56 PM
On a diagram for TL it shows front and rear mount as same part. Plus my front and rear mount are exactly the same too. Maybe the different # is for the direction the vacuum line comes out the bottom??
Old Jul 4, 2012 | 02:59 PM
Old Jul 4, 2012 | 03:12 PM
pdxtls6875's Avatar
Hmm... I see what you mean in the diagram. Thanks man!!!Can you see on yours if the vacuum line is in the same place??? Is there an aftermarket brand that you recommend? Rockauto.com has DEA, Beck/Arnley...
Old Jul 4, 2012 | 04:14 PM
Well I installed aftermarket mounts from XLR8. They are a solid mount no vacuum assist. The fact that I'm set forever on motor mounts is cool. There's some vibration at idle you can feel after the install but it fades considerably. It will never be as smooth (at idle) as factory mounts but they not gonna brake and make me go through another install so the shaking is a fine trade off.
Feb 25, 2020 09:57 AM
drone619
Jan 26, 2016 07:09 PM
08 NBP TL
Sep 8, 2015 08:49 PM
leerbgdup
Sep 6, 2015 11:01 PM
datadr
Sep 2, 2015 06:46 PM
