Break squealing help.
Old May 27, 2010 | 11:27 PM
OverGloc's Avatar
When i lightly press on the break its squeal but if i press it firmer it dont squeal what give? Change Pads and still no go! Need rotor? TIA
Old May 28, 2010 | 05:33 AM
my.daily'tl''s Avatar
Always Working In
I would suspect somethings rubbing down there.
Old May 28, 2010 | 10:49 AM
01tl4tl's Avatar
how are the rotors- smooth to the edge? if there is a ridge it will make noise
What brand pads?
how many miles on rotors- acura rotors?
ck your work with the DIY?
Old May 28, 2010 | 12:19 PM
fsttyms1's Avatar
BRAKES....... Did you put shims on with the pads? Did you use disk brake grease on the back of the pads? What pads did you use. Not all pads are equal, some will make noise while breaking in.
Old May 29, 2010 | 10:31 PM
OverGloc's Avatar
Had OEM brakes with when its started then change out to Wagner pads. did not see any shims when i remove the OEM pads will have to check it again. When i remove the OEM pads its had more then 80% life left! The only i did before its started squealing was Changing RIMS out Went from 17's to 20's then 16's.
Old May 30, 2010 | 06:20 AM
01tl4tl's Avatar
find out where there is contact under braking with the rim
OE pads have shims on them
not all new pads come with shims, but the use of brake caliper lube helps all brake operations
Did you simply throw pads on and not remove the rotors for cleaning with 150 sandpaper
If you got high miles and still have lots of pad- those things are probably glazed
Need to scour off the old pad material from rotors and bed in the new pads
Any ridge on the edges of rotor will cause a noise on initial or light braking
When you brake harder you go past that ridge
When something new happens after recent work- always suspect the recent work!
Is your car lowered??
Old May 30, 2010 | 10:08 AM
OverGloc's Avatar
Not Lower but will check for shims..
this might be the problem..
Old May 31, 2010 | 10:15 PM
fsttyms1's Avatar
So you replaced the pads, but didnt have the rotors turned or replaced?
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
dirleton
Sep 25, 2015 12:25 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
