Brake Problems
Brake Problems
I just put on new brakemotive front pads and rotors, and i took out for a test drive and when i hit the brakes they went to the floor. Then my car pulled to the left, and my passenger side brake stayed on at all time. Im just making sure the only thing it can be is the caliper. Im hopefully going to replace the caliper tomorow. Any thoughts on what else it could be
It doesn't have to be the calipers. It can be traced all the way up to the master cylinder. Maybe the caliper washers, maybe the lines. I would put my money on the rubber lines, probably bent it too much.
I would check all corners, just to be safe.
good find,,always ck work!!,,ensure brake line is secured back to strut
Did you flush brake fluid yet?
special order on the TL is LF= driver front then clockwise LF RF RR LR
sidenote this is gen2,,ck gen3 for your 05,,the bleed order is the same.
brembo calipers outer bleeder first,,then inner
mada51589
Jan 9, 2025 04:40 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
, problem resolved.
