Brake Light ON
Old Feb 28, 2008 | 08:08 PM
rocketlauncher's Avatar
Brake Light ON
Hi All
i have been getting this BRAKE LIGHT ON mostly during mornings. Lehme confirm that this is not the BRAKE LAMP LIGHT. Also, this light automatically disappears after 10-15 minutes however appears again when I start the engine again. HELP HELP HELP
Old Feb 28, 2008 | 08:47 PM
CrackerTeg's Avatar
Check your brakes/ brake fluid. More than likely, your fluid is a hair low. Happened to me a few weeks ago.
Old Mar 6, 2008 | 05:50 PM
rob-2's Avatar
My cap started to fail, $30 at the dealership stop the problem. They replaced the cap.
Old Mar 6, 2008 | 07:42 PM
Gfaze's Avatar
S E L L
Also if you're brake fluid is low, you should check for leaks. You shouldn't be losing any fluid in the reservoir at all.
Old Mar 6, 2008 | 08:22 PM
MurdaZ's Avatar
^^ exactly, theres a cause and effect for everything, dont just top it up, find out what is leaking, if u can and got the time, check the lines along the driver side for leaks, and the p-valve.....
but when did u do ur brakes? most likely what prob did happen is that ur pads are low, and now the fluid is all in the cavity of the piston on the calipers...bet my money on that..
Old Mar 6, 2008 | 08:34 PM
Never Summer's Avatar
I would bet my car on it that it's the master cylinder cap, a $30 part. It literally takes 10 seconds to take the old one out and put the new one in, I had the same problem and now it's gone away.
Old Mar 6, 2008 | 08:45 PM
redlinetl's Avatar
6th Gear
Brake Light On During Cold Weather
I have a similar problem with my 2000 Acura 3.2 TL in cold weather only. I suspect a brake or wheel sensor as I have no brake fluid leaks. It can also be the ABS system. I have not yet checked computer fault codes but will do so this weekend.
Did you determine what triggered your brake light?
Thanks,
Ted
Old Mar 6, 2008 | 08:56 PM
Thanks,
Ted
Same problem I had previously, the master cylinder cap fixed that right up
Old Mar 7, 2008 | 07:57 AM
bibledriver's Avatar
Something is missing...my
Been happening to mine too in the AM. I think I will do like 2000T said and purchase a new cap. I know there are no leaks, and brand new brakes (full fluid). Is kind of annoying.
Old Mar 7, 2008 | 08:17 AM
fsttyms1's Avatar
Dont replace teh cap just yet. Take it off and clean it. There is a float on it that gets hung up. Just clean every thing with brake fluid and reinstall. see if it goes away. Also top off any brake fluid thats needed.
Old Mar 7, 2008 | 03:58 PM
redlinetl's Avatar
6th Gear
Brake Light On
Thanks everyone for our feedback. That was very helpful.
RedlineTL
redlinetl's Avatar
6th Gear
Brake Light On
Thanks everyone for your feedback. That was very helpful.
RedlineTL
Old Mar 8, 2008 | 06:38 PM
djarovsky's Avatar
There is a TSB on this issue:
http://www.in.honda.com/Rjanisis/pubs/SB/B03-029.PDF
Old Mar 8, 2008 | 10:37 PM
redlinetl's Avatar
6th Gear
Honda TSB
Thank you for sharing the very informative Honda TSB. That answers my question, and I appreciate your help.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
