Brake Indicator came on
Old Jul 1, 2008 | 03:38 AM
azn_xxxd's Avatar
.a BUM with SMG...
Hi guys, a few days ago, the Brake Indicator on the dash came on and stay that way every time i apply the break. So is there something wrong with my break or any suggestions
Thanks guys
Old Jul 1, 2008 | 04:45 AM
01tl4tl's Avatar
look at the fluid level in the master cylinder- if its down the light will come on
Read the owner book for other things that will trigger the warning light
Old Jul 1, 2008 | 05:00 AM
azn_xxxd's Avatar
.a BUM with SMG...
Thanks 01tl4tl , so the fliud level is the only cause for this ?
Old Jul 1, 2008 | 05:15 AM
'03TL-S's Avatar
Most likely it's the master cylinder fluid being low. Refill and check back with us to see if it still stays on.
Old Jul 1, 2008 | 08:30 AM
fsttyms1's Avatar
That or the float on the Brake cap
Old Jul 1, 2008 | 04:53 PM
azn_xxxd's Avatar
.a BUM with SMG...
hey guys, i did check the fluid but couldnt see the line limit of it, but when i open it up, he liquid reached to the top . So that would be ok right. Man im to young and i dont really know much about cars. Thanks for your helps.
Old Jul 1, 2008 | 07:27 PM
fsttyms1's Avatar
Look at the side of the master cyl. It has lines of max and min. You should see the fluid level. On the cap when you pull it out there is a float that moves up and down. Make sure it moves up and down freely.
Old Jul 1, 2008 | 09:53 PM
wildcat71's Avatar
02 NBP TL-S W/Navi
did you possibly happen to hit the emergency brake pedal, 1or2 clicks may not be enuff to apply the E-brake, but it will cause the brake light to light up.
Old Jul 2, 2008 | 11:51 AM
acutee's Avatar
It could be pads are low bringing the fluid below min level, emergency brake is on, fluid reservoir cap is defective.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
