Blower Motor or resistor
Old Jul 5, 2015 | 03:03 PM
JRhodes88's Avatar
Need an OEM lip kit on my
A/C just stopped blowing air last night.
Issue persists on all different settings (Fan min, Fan max, Full Auto).
I'm about to order a blower motor, but want to make sure it is not possibly the resistor first before doing the repair. To my knowledge, no wires have any signs of melting or corrosion. All fuses look good too.
Should I try to jump the motor to see if it works or maybe take the resistor out look at that?
On a side note...how does the resistor wire unplug from the unit? I didn't feel any typical clip or push mechanism on it.
Old Jul 5, 2015 | 04:26 PM
01tl4tl's Avatar
you looked at the power connector under front of glovebox? that's the problem area
Often when it goes bad and arcs- it takes out the resistor
The blower motor does fail too- the cars are getting on in years, spin it by hand
then try jumping it
the resistor is to reduce fan speed from max to whatever you want
Never order parts before taking it apart and knowing all the things to buy!!
Old Jul 5, 2015 | 04:27 PM
01tl4tl's Avatar
sometimes its just the power connection if you are lucky!
cut back burnt wire and splice in a new section of wire without a connector
the resistor has a cover/heat shroud over it
Old Jul 5, 2015 | 08:24 PM
JRhodes88's Avatar
Jumped the motor, spun up as expected.
So I think I can rule that out. Again, the wires look fine. No corrosion or melting.
Old Jul 6, 2015 | 07:20 AM
JRhodes88's Avatar
UPDATE:
Switched out the resistor with a new one.
Problem is resolved. A/C is back to blowing strong, cold air.
Old Jul 13, 2015 | 05:06 AM
Alex D's Avatar
Just to further add to this, 9/10 times if the subharness isn't melted it is the resistor on these cars that goes bad that causes the fan to not work or AC/heat to not work.
Old Jul 24, 2015 | 03:26 PM
bigjoe85's Avatar
8th Gear
I am having a similar issue, the blower motor was replaced and is working just fine but im still not getting any air out of the vents. I tried replacing the resistor and still no dice. Any help would be appreciated
Old Jul 24, 2015 | 06:49 PM
Seabright's Avatar
Here's a thread on the same subject. Maybe this is your issue:
https://acurazine.com/forums/problem...stions-925737/
Old Jul 24, 2015 | 08:10 PM
01tl4tl's Avatar
see diy on vent mechanism
If you get adjustable blower speed, the resistor is fine
08KBP_VA
Oct 22, 2019 01:55 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hashbrown
Sep 29, 2015 12:13 PM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
