is it the battery or the starter?
Old Sep 8, 2009 | 09:39 PM
nhn23's Avatar
I live in
okay, my car has been acting up. about 2 weeks ago i tried to start the car. i cranked it and it made no noise. so i kept cranking it and still no noise.. so i let it sit and wait like 5 mins then cranked it again and bam! it starts. it worked fine until today, i cranked it and it made a clllliiiiiiickkkkkk noise then all the lights dims out. so i jumped the car thinking its the battery, it took 2 jumper cables for it to start(why is this?). okay so i drove the car around for about 10 mins for it to charge and came back home, turned off the car and tried to restart it, same thing happened (clliiiiiccccckkkkk) then the lights dims out. so i had another battery laying around so i swapped that out and jumped that battery too because it was sitting there for awhile. again it took 2 jumper cables to start. what i dont get is that when i direct connected the jumper cables to my - and + cables on my car, it wouldnt start. then when it finally started, i let it sit for 10 mins and drove it around for another 10-15 mins. when i got home again i tried to start it up again and it worked. so my question is, is the starter going bad or is it just my battery? OR MAYBE ITS THE ALTERNATOR?!!
Old Sep 9, 2009 | 12:51 AM
Alex D's Avatar
Try cleaning your battery terminals first and see if that helps.
Old Sep 9, 2009 | 04:40 AM
Rajca's Avatar
wham bam thank you ma'am
battery. most shops will test the system before replacing it.
Old Sep 9, 2009 | 07:02 AM
totaledTL's Avatar
Battery voltage after sitting a while w/out engine running? Had the battery load tested? Battery cables clean & tight on BOTH ends?
Old Sep 9, 2009 | 07:49 AM
fsttyms1's Avatar
Most likely your battery. Have it load tested.
Old Sep 9, 2009 | 04:26 PM
nhn23's Avatar
I live in
tried cleaning it and everything. it is an everyday car so it never sat for over 24 hrs. it seems to work fine now but im afraid its gonna act up again.
Old Sep 9, 2009 | 04:27 PM
fsttyms1's Avatar
Go to any auto parts store or sears and have it load tested. It will tell you if its the battery.
Old Sep 9, 2009 | 06:19 PM
travs 2002 tl type s's Avatar
u coulld have a volt leakage but deff have it load tested like fsttyms1 said
Old Sep 28, 2009 | 11:31 PM
Its either the battery or the starter, both are easy to replace. Have them both checked out at your local auto parts store. The starter will have to be taken out for them to test it. PepBoys has a lifetime warrantied starter for around 114$, I just bought one this weekend and installed it.
Old Sep 28, 2009 | 11:37 PM
Also when you bring in the battery to have it tested/charged and you still notice the car not starting the next day. Then you know two things: the battery is not holding its charge (if you take it in the next day and they say it needs to recharged..then this confirms that its not holding the charge), second, your starter is bad. I bought my battery at Walmart which had a 3 year replacement and 9 year pro-rate, compared to the auto part stores that only give 1st year replacement and 3 year pro-rate....eventhough they define this as a 3 year replacement.
Old Oct 19, 2009 | 03:44 PM
rayjay777's Avatar
It is your starter motor. I just got back from Acura and they gave me a quote for $600 installed. The last time I bought a starter it was $40. I am still in shock.
Ray
Old Oct 19, 2009 | 05:30 PM
Rajca's Avatar
starters (new) are around $150-200. installation is easy. 30 min. and its done. easy to get too and some basic hand tools is all u need.
Old Oct 30, 2009 | 06:47 PM
Monterey99's Avatar
5th Gear
99. Tl. Have the same problem
Hi. I own a 1999 tl. I have never had a problem starting my car until today. I went to start it and nothing. No noise. Nothing. My battery seems fine but my starter isn't making a sound. I don't think jumping it will work but it's worth a shot. Here is my email. If you figure it out I would appreciate any input. J.ballard90@yahoo.com. Thanks
Old Oct 30, 2009 | 07:03 PM
nhn23's Avatar
I live in
my problem was the battery. i had autozone load test it and it failed. i purchased the Optima red-top battery from them. i gotta say, its one strong battery.
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
agupta3224
Sep 22, 2015 08:08 PM
