Battery needs replacement?
Old Mar 2, 2008 | 04:19 PM
100degrees's Avatar
Just wondering what are the symptoms one gets when a battery should be replaced other than the obvious dead battery. TIA
Old Mar 2, 2008 | 05:51 PM
sbuswell's Avatar
I need 2 more gears
Slow starting, slow power equipment operation. Headlights dim when you use other power equipment in the car. Get a $10 battery tester at autozone or some parts place and see if it's running low. If it is just replace it with an Optima.
Old Mar 2, 2008 | 08:50 PM
mcflyguy24's Avatar
Or if optima is too expensive (I couldn't justify the cost being as I'll prob not still have the car a 8-10years from now when the optima dies) get an interstate mega-tron w/5year warranty. 800 cold cranking amps is plenty for here in the northeast. You want to get model MTP-24. I'd recommend optima though if you have a sound system w/ amps in the car or if you just don't want to worry abut your battery dying again.
Old Mar 2, 2008 | 09:28 PM
01tl4tl's Avatar
If you go to any major parts store- they will come outside for FREE and test the battery, starter load and alternator output for you.
It will say what you need or if all is well.
Battery life is 3 to 4 years and then they die- just past warranty usually.
Costco sells good batteries, most parts store brands will do for normal drivers with stock stereo.
Old Mar 2, 2008 | 11:03 PM
Gfaze's Avatar
S E L L
Old Mar 3, 2008 | 12:24 PM
100degrees's Avatar
Thanks for all the help guys!
Old Mar 7, 2008 | 10:30 PM
TL Type S fan's Avatar
03 TL Type S Noble Green
I have an 03 TL Type S and I noticed a couple of things with mine I thought were interesting.
The express down window stopped working. The lights on the front drivers door memory switch didn't light any more.
I can't complain, the battery lasted almost 6 years. I got mine at my local dealer. 150 installed and they un locked my radio. It was raining at the time and I didn't want to screw around looking for a deal and then having to go to the dealer and have them unlock my radio.
Old Mar 8, 2008 | 10:01 PM
mcflyguy24's Avatar
To fix your window auto down up feature, you roll your window down and hold the button in for three seconds and then roll it back up and hold the button in for three seconds. Happens every time I disconnect the battery, I have to reset the window, put in the radio code, and reset my drivers memory settings. The light on the memory settings won't light until you make new settings again. If your just died randomly it's an LED that went out, no big deal.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
