battery and brake lights
Old Dec 4, 2014 | 10:03 PM
bscott's Avatar
I replaced my altanator a few weeks ago. The same battery and brake lights keep coming on. What could it be now? Scared of being broke dwn.
Old Dec 4, 2014 | 10:40 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Was the battery light on prior to the replacement of the alternator ?
Make sure the bolts holding the alternator are snug and also check the cables going to it
Lastly make sure the belt is actually installed.
Old Dec 4, 2014 | 11:01 PM
01tl4tl's Avatar
what made you replace the alt?
were there problems with battery not recharging?
shop/parts store tested as bad alt, but battery was still ok?
parts store test for free- what are the batt and alt readings now?
Old Dec 5, 2014 | 07:08 AM
3.2TLc's Avatar
Welcome Bscott !!!
Yeah, if the warning lamps were on before the alternator replacement, recheck your wiring connections and grounds. If nothing apparent, have the electrical charging system load tested and check for scavenger drain.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
HeloDown
Sep 8, 2015 06:51 PM
