Bad Rotors? Replacements?
Old May 5, 2010 | 03:58 AM
FireNation23's Avatar
Every porn dvd in a
My steering wheel shakes quite a bit anytime it seems like I'm hitting the brakes at 45mph+ . Sometimes when I accelerate hard, it shakes from 50-60 mph as well.
I had the engine mounts replaced when the tranny was replaced. It's been about 30k since the mounts have been replaced. I have roughly 50k on the rotors.
If it's the rotors, should I replace with oem rotors or get some drilled/slotted rotors. My friend told me that drilled rotors are weaker because they're drilled, if I was to get aftermarket, just get some slotted. Thanks for the help.
Old May 5, 2010 | 05:59 AM
piggylover1985's Avatar
If it shake when you use the brake then your rotors might be warp. The brakes has nothing to do when you accelerate from 50-60 mph and it shakes, unless the caliper hanging,should look into alignment, tire wear unevenly,stiff axle or something else.
Old May 5, 2010 | 06:10 AM
I have slotted & cross drilled front and rear with ceramic pads, braking distance has been improve, it could be weaker but it grabs really good.
Remember not to buy cheap rotors as they will warp in a short time.
Old May 5, 2010 | 07:52 AM
OEMAcuraPartsTim's Avatar
Former Sponsor
If it's shaking when accelerating, it's not the rotors. I'd lean towards a wheel bearing replacement, which isn't uncommon in the 2G TL.
Old May 5, 2010 | 04:21 PM
If it's the wheel bearing it would make some noise woudn't it ?
Just a thought.
Old May 5, 2010 | 07:21 PM
Every porn dvd in a
I have Oem brakes and rotors, they should last around 80? I have a lot of highway miles, so should last more than 50k
Old May 5, 2010 | 08:15 PM
They should, but doesn't mean they would lol. If the rotors doesn't look to bad, you can even have someone turn them for you. More than likely be the front rotors.
Old May 5, 2010 | 08:42 PM
Every porn dvd in a
how long your drilled slotted rotors last you so far? I don't wanna dish out 400 for drilled slotted rotors and have them crack on me fast.
Old May 5, 2010 | 09:48 PM
Steen27's Avatar
If you buy quality rotors - they won't crack... unless you were to somehow do a super hard stop from 120+mph and immediately park it in an ice cold lake or something... lol even then it would take a lot to make quality rotors crack. Cheap ones on the other hand... anything is possible - buyer beware - you get what you pay for with brakes.
Old May 5, 2010 | 11:23 PM
Every porn dvd in a
Thinking about Rotora drilled & slotted rotors. Should I get the steel braided brake lines as well??
excelerate has a promo going on. looks like a good deal
Old May 5, 2010 | 11:43 PM
hANDYcaptd's Avatar
It's the Halladay season!
You only need slotted for performance. Drilled doesn't add much more cooling, mostly looks.
And it actually is more prone to cracking.
SS lines will improve pedal feel and braking. I would get it.
Old May 6, 2010 | 08:25 AM
Every porn dvd in a
anyone have rotora rotors drilled & slotted or just slotted crack on them? any help from 1st hand use is appreciated
Former Sponsor
Just a thought.
Believe it or not, no.....at least not in the case of the 2G TL. They seem to develop a very small amount of lateral play, which causes the shake.
The only time the brake rotor will cause a shake is when the brakes are applied. And, of course, if the fronts are shaking, you'll feel it in the steering wheel when you mash the pedal.
Old May 6, 2010 | 05:54 PM
[quote=OEMAcuraPartsTim;11991755]Believe it or not, no.....at least not in the case of the 2G TL. They seem to develop a very small amount of lateral play, which causes the shake.
gotcha.
Old May 13, 2010 | 10:39 PM
Every porn dvd in a
Can you price me on the front wheel bearings. Left and right and set of 4 rotors (front and rear) or give me the part #'s. And how much would shooing be? Thanks
Old May 13, 2010 | 11:38 PM
junteschan's Avatar
I once installed a Centric slotted front rotors a few years back.
Its got a moaning sound upon brake application.
It warped after probably 2 yrs so I went back to stock.
If it warps then time to go w the cross drilled ones.
I have slotted/cross drilled front rotors on my tundra and
still works well todate.
Old May 14, 2010 | 07:04 AM
Luke7's Avatar
WNC Real Estate Sales99TL
I bought Brembo Blanks and Acura Pads. I got 93,000 miles out of the last set of Acura pads. No squealing, not much dust. There are better pads and rotors as stated on this site/but this setup works great on my car. Not into fast preformance driving. I also replaced the front brake lines since in hot weather my car would pulse when stopping in hot weather. I spent around $380 for this set up and did the work myself.
Old May 14, 2010 | 08:46 AM
Former Sponsor
You can either check the www.oemacuraparts.com website, or just drop me a PM, and I'll be happy to give you the quote myself
Old May 14, 2010 | 12:38 PM
01tl4tl's Avatar
Tim is correct- wheel bearing- axle bearing- cv joints etc will cause a shake on accelleration
Bearings are tricky to hear with the naked ear!~!
get in there with a mechanics stethascope and your whole world view will change~
I mean listen with that tool and you should be able to hear the offending part with it running on jackstands
ziners please PM or call vendors for prices so we keep the threads on topic- thank you
Old May 14, 2010 | 12:57 PM
pimpin-tl's Avatar
All drilled rotors are more prone to cracking and it doesn't matter of the quality. It is just the way it is. They don't recommend them at all in road racing as they can fail.
Old May 15, 2010 | 12:30 PM
01tl4tl's Avatar
euro gt1 is allowing them and I though I saw some in us endurance races on tv this year
But those rotors cost over a grand per~~ then get signed and sold off after the race
unless you live on top of a mountain and commute to the bottem, or autocross race the car or extreme high water puddle contact- those examples will shine with crossdrilled
Side slotted are cool looking and they function to allow an escape path for expanding pad gasses that come out under really hard and repeated use, they can be high enough pressure to force the pads away from the rotors with your foot on the pedal!! not a great feeling aproaching turn 7
The slots give an escape path so there is not an issue
The major cooling in rotors come from the center vane configuration- how it extracts hot air from the center and gets it to the outside
does it keep the heat even thru vane design so rotor temp doesnt vary across the width (racingbrake.com)?, or do they do little or extract it so heat varies etc
All that has a direct impact on rotor life and prone to warping
Mettalurgy varies with makers intent of: mom drives the car (TL theory) or young drivers thrashing, or slipping in under scca rules with a special part (see legend calipers)
stock honda stuff is low budget,,as I often say - what they got you to pay for the car has no relation to what they spent making it
Old May 28, 2010 | 12:58 PM
Every porn dvd in a
Thanks, I'll probably go with the brembo blanks and pads set up
Old May 28, 2010 | 02:58 PM
Every porn dvd in a
and probably change the wheel bearings, I got 140k on the car, might be a good time to change.
Old May 28, 2010 | 05:34 PM
thepreludedude's Avatar
i have used brembo blanks n numerous cars and never had a problem. if you want more bite you might look into hawk or axxis pads but they have some drawbacks like more dust or more noise.
Old May 28, 2010 | 06:35 PM
pimpin-tl's Avatar
mada51589
Jan 9, 2025 04:40 PM
jblessing
Aug 8, 2018 09:43 PM
gqdabien
Sep 8, 2015 11:41 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
