Automatic Tran Shift Delay
When my 03 TL when cold or after sitting awhile DELAYS when I go from Park to Drive. The engine revs during the short delay, then with a clunk it goes into Drive and shifts through the other gears ok. It consistently does this until warmed up then shifts ok without any problems. After sitting awhile it goes through this again. Fluid level is ok with good color and smell. Anyone know if this is a electronic, solenoid, or transmission problem? I'm off warranty. Anyone have this problem, solutions?? Thanks
Mines been doing that for awhile and it seems fine a lot of other people have said the same thing so I think your alright. Apparently they all seem to do that.
mine's an 02 and I am considering taking it in to get it checked out. If I do get it checked out, I will post the dealer's findings.
If I shift it from P -> D about a second delay with a clunk. If I shift from D -> R a noticeable cluck, and when I put it back to D another delay and a clunk. I don't think it's normal, so I will take it in to get it checked out while still under the extended warranty.
Mine does the exact same thing! Clunks into gear cold. Revs during delayed shifting when cold. I just baby it until warm. Changing fluid did not help. I think it is related to the PCM. Would like solution myself.
SidhuSaaB
May 30, 2020 12:40 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
Hines57
Sep 24, 2015 01:58 PM
