Anyone replace there Trans/engine Mount?
Old Aug 17, 2006 | 04:19 PM
h22aDc2's Avatar
Well my car is currently at acura getting its free tranny installed today, and they called me to tell me that my front engine/tranny mount is leaking its oil filled mount... I just wondered if anyone eles has had this problem? or if its just something there tryin to get me on... Thanks guys
Old Aug 17, 2006 | 04:27 PM
fsttyms1's Avatar
Its a fairly common issue with these cars. It would be cheapest to let them replace it now with the tranny out
Old Aug 17, 2006 | 05:14 PM
JAYCEE's Avatar
Front motor mount and tranny mount are two different things. Front motor mount
is the only mount thats oil based. Make sure you ask for the old mount back just to be sure it was needed. I had both front mount and side engine mount replaced when my tranny was replaced and Yes, its worth doing it with the tranny already out.
Old Aug 23, 2006 | 05:51 PM
civic2000's Avatar
I am getting my front and passenger side motor mounts replaced today. My TL has 88,000 mi on it. I thought it was shifting kind of hard from 3rd to 4th. The TCS goes on to for no reason, so they will replace TCS unit. The other reason is maybe the battery cables are bad. Could a bad battery cable make the ECU throw out a bunch codes?
Old Sep 23, 2006 | 06:28 AM
chewi's Avatar
so I assume engine mounts gets damaged more easily when our cars go over harsh bumps from the roads eh?
I've seen people going through speed bumps without slowing down at all and I keep thinking they will need to replace their engine mounts in no time lol
Old Sep 23, 2006 | 09:40 AM
fsttyms1's Avatar
Design and motor are more likely to damage them than bumps in the road. How aggressive you take off and brake causing the motor to flop around is what tears them up
Old Sep 24, 2006 | 07:32 AM
chewi's Avatar
o thanks... I do drive pretty aggressively.... I might need to get them checked out before my warranty expires.
bnaritomi
Feb 17, 2016 03:22 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
