ammco
ammco
so i was at ammco getting my transmission checked and they said my transmission is ok its my pcm or my abs computer that is messed up. does that sound right? i thought that when the abs and tcs light comes on thats a sign that the tranny is about to go. and my speedometer would jump like crazy
o well i hooked up a genesis to my car and it said right rear wheel speed sensor mulfunctioning.
p1676 code
what am i suppose to do with this code? the guy at ammco said i might need a new pcm. i also got a p0506 code to but ima try to clean the iac valve and see if that will clear that up
From Acura:
DTC P1676: FPTDR Signal Line Malfunction
'99 model
Reset the PCM.
Start the engine and wait 10 seconds.
Is DTC P1676 indicated? YES - Go to step 3.
NO - Intermittent failure system is OK at this time. Check for poor connections or loose wires at the ABS/TCS control unit and the PCM.
Step 3- Turn the ignition switch OFF.
Disconnect the PCM connector E (12P) and the ABS/TCS control unit 16P connector.
Check for continuity between body gound and PCM connector terminal E1.
Is there continuity?
YES - Repair short in the wire between the ABS/TCS control unit and the PCM (E1).n
NO - Go to step 6.
Check for continuity between ABS/TCS control unit 16P connector terminal No. 1 and PCM connector terminal E1.
Reconnect the PCM connector E (12P).
Connect PCM connector terminals E1 and C28 with a jumper wire.
Reset the PCM.
Start the engine and wait 60 seconds.
Is DTC P1678 indicated? YES - Substitute a known-good ABS/TCS control unit and recheck. If the symptom/indication goes away, replace the original ABS/TCS control unit.n
NO - Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.n
Is there continuity? YES - Go to step 7.
NO - Repair open in the wire between the ABS/TCS control unit and the PCM (E1).n
Basically, it's an ABS/TCS control unit failure......
__________________
'99 model
Reset the PCM.
NO - Go to step 6.
Reset the PCM.
__________________
DTC P0506: Idle Control System RPM Lower Than Expected
This is straight from Honda
Remove the intake air duct from the throttle body.
Check for dirt, carbon, or damage in the throttle bore.
Is there dirt, carbon, or damage in the throttle bore? YES - If there is dirt or carbon, clean the throttle body. Also check for damage at the air cleaner element, then go to step 9. If there is damage in the throttle bore, go to step 8.
EDIT: Cleaning your IAC valve is another possibility for remedying this code.
