99' TL w/NAV + BOSE help
I have one rear speaker that is not speaking. Both fronts work and the sub works. Car has the old talking NAV system and she still talks fine. I never get in the back so I didnt notice untill I was fooling with the fader and ballance controlls.
If someone could tell me were the rear door speakers are fed from and what I could do to test before ripping the rear door pannel apart? I am sure the feed wire is run through the rubber flex tube to the chassis but from there??? Under front door sill? Under carpet along center console? Is there a detailed wireing diagram available anywhere?
BTW eveything is factory-stock-unmodified
Thanks in adavance...
If you have any special knowledge on this subject please send to driscoll2@comcast.net
Door panel
Is the panel removal a hard job or an easy driveway job? I dont want to screw up my leather!
""" OR """ Should I consider having better speakers installed proffesionaly and let them worry about the door panels?
If so, what kind would be suggested? Whatever is on-sale at Best-Buy or some high-end brand?
Are the ones in the door coaxial, triaxil, component or just plain-old full-range speakers?
B.T.W. I get better info from this web-site than from any other place!
Thanks to all and keep up the good work!
Medinak12
Sep 23, 2015 07:11 PM
SilverKnight
39
Feb 18, 2004 01:22 PM
Bluto
Mar 6, 2002 10:52 AM
