Replacement motor mounts no vacum
Old Nov 26, 2007 | 08:45 PM
Timslunch2's Avatar
I put in a set of front and rear motor mounts and there was no nipple for the vacum lines. I pluged the vacum lines and put them in. Is there any pro's or con's to the vacum lines? And also what spark plugs should I get?
Old Nov 26, 2007 | 09:12 PM
phee's Avatar
I got the Shifts
duno about the vacuum lines, but you def gotta go with NGK's most people use the iridiums, but i got the platinum ones. and i feel the diff
Old Nov 26, 2007 | 11:33 PM
02type-s's Avatar
-Arsenic-
Iridium is an upgrade from platinum
Old Nov 28, 2007 | 06:24 AM
Timslunch2's Avatar
Whats the deal with the motor mount that dont have vacum?
Old Nov 29, 2007 | 07:24 AM
Timslunch2's Avatar
Nobody knows about the vacum lines on the motor mounts? I bought Boush 4+ and I think they make my car vibrate at Idel. Any input would be much help. Thanks
Old Nov 29, 2007 | 08:34 AM
fsttyms1's Avatar
What do you want us to tell you? The TL is supposed to have vacuum assisted mounts. Not having them wasnt a option for the TL. The fact yours didnt come with them leads me to believe they are cheap knockoffs or not for the TL.
Old Nov 30, 2007 | 06:54 AM
Timslunch2's Avatar
I want ot know if there are any bad effects to having them vs. the ones with them if you read my post previously. Thats what I would like to be told. I'm sure someone else here has ran into this problem and i was looking for input from them or something from who may know.
Old Nov 30, 2007 | 09:45 AM
fsttyms1's Avatar
well i dont know of any bad effects, other than possibly a rougher idle? You will want to plug the vac lines not used. I personally would get ones that are right.
Old Nov 30, 2007 | 12:45 PM
Timslunch2's Avatar
Yeah my car idels rough now. That makes sense. I thought the spark plugs i used where the cause of that. i used boush 4+ could they also cause a rough idel? my car dosn't misfire but accelerates like sh!t. I would replace the motor mounts but that rear one was a b!tch to put back in.
Old Nov 30, 2007 | 07:31 PM
sbuswell's Avatar
I need 2 more gears
The only mounts you would want to use that are not hydraulicly assisted are the new Innovative mounts Excelerate is selling. That is a cool mod that should make a very noticeable different when accelerating hard especially from a dead stop. I definitely want to get those when I have some extra money.
Feb 25, 2020 09:57 AM
bnaritomi
Feb 17, 2016 03:22 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
