99 tl overheating help!!!
Old Feb 12, 2014 | 10:35 AM
eegastelum's Avatar
3rd Gear
my TL has been overheating when it idles I can smell the coolant fluid. When I open the hood I can see coolant residue at the radiator neck and cap. I have replaced the radiator, oem radiator cap and thermostat and the ac condenser fan and I still have a problem. I've been told it might be the head gasket can u guys help
Old Feb 12, 2014 | 11:36 AM
cincinattlguy19's Avatar
06 NBP 6MT TL
Start by checking relays and fuses for the fans. Make sure your radiator cap is on correctly, as stupid as that sounds. How is the coolant level?
Old Feb 12, 2014 | 11:57 AM
eegastelum's Avatar
3rd Gear
When I bought the new radiator it came with a cap and I kept overheating so I bought an oem cap from napa autoparts. The coolant level is full. I put my hand on the radiator cap and I can feel it bubbling
Old Feb 12, 2014 | 12:06 PM
06 NBP 6MT TL
Is the coolant level overfilled? If there is too much coolant, I believe it may begin spurting out of the little hole in the radiator cap. How do they coolant lines look? Dry-rotted or cracking?
Does the temperature needle inside the car actually move towards HOT, or can you just smell coolant?
Old Feb 12, 2014 | 12:36 PM
eegastelum's Avatar
3rd Gear
the radiator fluid over the radiator looks like a white haze coming from underneath the cap between the neck in the cap and the temperature gauge goes up 3/4 of the way sometimes even higher
Old Feb 12, 2014 | 06:10 PM
3.2TLc's Avatar
overheating.........
~ A few questions that might help us help you :
* Are both cooling fans activating ?
* Was the cooling system properly burped of any air pockets ?
* Did ya use the "OEM" 2 stage T-stat ?
* Does your exhaust puff white clouds of smoke ?
* Is the oil level higher than normal and appear milky ?
* What did the old coolant look like before ?
Old Feb 12, 2014 | 06:46 PM
MarcDavidoff's Avatar
also did you use Honda Type 2 coolant or something else? Whatever you used it should be a 50/50 mix of water/coolant. Honda type 2 is premixed. Your thermostat could be sticking although if it is a Honda OEM tstat they should stick open not closed. Is coolant overflowing from your coolant reservoir?
Old Feb 13, 2014 | 09:25 PM
01tl4tl's Avatar
was it redlined on temp several times before fixes?
spark plugs will confirm head gasket blown ,the rising oil level or foamy rad fluid = blown head gasket
Frathora
Sep 28, 2015 11:29 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
Jezek
Jun 20, 2006 11:30 PM
gincali
May 17, 2006 09:01 PM
