2003 TL-S Blower intermittant operation
Old May 16, 2012 | 08:13 PM
nishant11's Avatar
I drive 2003 TL-S at 125000 miles. Owned for 4 years now and did not experience any major issue so far.
Yesterday I noticed blower dead. While driving for few minutes with A/C on but nothing happening, without doing anything, blower came on as normal functioning. It worked for few minutes and died again without touching anything.
From these symptoms, can you please advise what are the possiblities or areas of concern.
My hunch is possible electrical issue like AC relay or something like that.
Please advise.
Old May 16, 2012 | 09:06 PM
nishant11's Avatar
Service bulletin
Did some research and found probable cause.
http://car.justanswer.com/uploads/ac...912_blower.pdf
I now need to check for issue and buy Blower Motor Subharness: P/N 04321-S0K-A00 when confirmed.
Old May 17, 2012 | 07:07 AM
Luke7's Avatar
WNC Real Estate Sales99TL
the wiring harness is very accessible right under the dash. Mine did the same thing. The wiring harness that connects to the blower motor was corroded and not making a good connection. I cleaned the connections and all is good. 130,000 here. 2003 Type S
Old May 17, 2012 | 09:54 AM
01tl4tl's Avatar
the connector lead is too short and the wires can be pulled out or just crudded
acura dealer has an update kit with longer wires and new connector setup ~$20
easy diy
some have prob with the resistor for blower motor, located on mount for motor
remove its heat sink/cover and inspect
time for new cabin filters and shop vac anywhere you can reach!!
Old May 18, 2012 | 01:07 PM
AMGala's Avatar
Lamborghini Aventador FTW
easy diy
Do you know what the part number is?
Old May 19, 2012 | 11:47 AM
01tl4tl's Avatar
if I knew the part number I would have posted it~ sorry
call one of our sponsoring dealers and talk with a human
tell them you want the blower motor connector update kit- and our 25-30% discount
Old May 19, 2012 | 09:41 PM
nishant11's Avatar
I bought improved harness for blower 04321-S0K-A00 from Acura dealer for $8.
Old May 20, 2012 | 08:16 PM
01tl4tl's Avatar
thanks for that number,,applies to all gen2?
I only knew it was under 20 bucks,,,8 is a bonus
did it fix the problem? resistor was not harmed?
installed new cabin filters etc?
Old May 21, 2012 | 11:09 AM
totaledTL's Avatar
The # was given in post #2 also...
Old May 22, 2012 | 08:30 PM
pimpTL's Avatar
6th Gear
I just recently changed to the the blower motor to a new one and switched the updated wire harness and swapped out the transistor and my ac is still weak.
can anyone chime in on this? possibility I might have to recharge the a/c system?
Old May 23, 2012 | 09:29 AM
01tl4tl's Avatar
ac weak how?
does the passenger side radiator fan come on with ac on?
do BOTH fans run with ac on?
does the cabin air temp not drop down fast?
do you have control knobs or electronic ac controls?
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
hashbrown
Sep 29, 2015 12:13 PM
Brandle34
Sep 23, 2015 07:20 PM
