2002 tl p1457
2002 tl p1457
Hi!
I know it's a common problem and that other threads have been opened before but I need info anyways
I have just replace the '17310-S0X-A02 Vapor Canister Purge Valve'. Also when we remove the gas cap we hear the whoosh sound so that tells me i should not have leak... But the code came back 2 days later... Anything else I can try before I take the car for a smoke test at the mechanic?
Thanks for any help
Thanks for any help
If you don't have it then download the Service manual here
Starting on 11-213 will give you some testing ideas. If you don't have a vacuum pump and multimeter then you might be better off taking it in to a shop rather then replacing random parts.
Hi!
Thanks for any help
Thanks for any help
Healthy would be anything that doesn't trigger an EVAP leak CEL.
That being said, The whoosh on mine is noticeable if you are listening for it. An empty tank will have a more pronounced rush of air than a full tank.
