2001 TL 3.2 Power Window issue
I replaced the Window Regulator on the Driver's door and upon testing, the window barely moves up or down. I can force it by pulling the window up or down while pressing the button, but obviously it isn't working right. I am at a lost for the cause. It is a brand new regulator and it sounds like it is working just fine. It just seems to be getting caught somewhere.
Anyone have a similar issue? I personally don't think it's a problem solved by a silicon spray as it is completely stopping if I don't pull or push on it.
Much appreciated!
Much appreciated!
Thank you for your reply Arkady! I did pull it apart and found that nothing was blocking it. I went and bought some Silicon spray to just try it anyway and sure enough, it worked. I guess after 2 years of not moving, it just needed a little lubrication.
Appreciate the help!
Thanks for the welcome as well. I hope to learn a lot here.
dubz ASPEC
Jun 3, 2025 08:48 PM
