D/S power window & power locks issue
Old Dec 6, 2010 | 01:45 PM
u1ricewidat's Avatar
If there is a thread on this please let me know. I didn't find one specifically about my issue.
'03 Acura TL 80k
The 3 switches that control the passenger and the 2 back windows do not work on the main d/s power window switch. The d/s pw switch is the only thing working. All other windows on their side work just fine. Back to the d/s pw switches, the mirror, the heat warmer for the mirror and the window lock(child safety lock) still work. Could this be that I need to get a completely new d/s power window switch unit or is there something that I should check on first?
For the power door locks, the d/s power door lock switch is not working but the passenger door lock switch is working just fine. Possibly a new door lock actuator??
thanks in advance for the help!
Old Dec 13, 2010 | 09:42 AM
has anyone ever had this specific issues?
Old Dec 13, 2010 | 10:10 AM
totaledTL's Avatar
Have not had that issue, but you might try disconnecting the battery for a few min. Is the battery in good condition or could it be marginal?
Make sure to have your radio code & nav. code (if you have nav.) on hand.
Old Dec 13, 2010 | 10:41 AM
i have tried disconnecting the battery but it still fix the issue.
Any other ideas?
Oh my TL is a non type s w/o navi.
Old Dec 13, 2010 | 11:40 AM
steeze4twenty@hotmail.com's Avatar
broken wires in door?, try holding down a switch while opening and closing the door.
Old Dec 15, 2010 | 09:56 PM
im getting the same result.
Its starting to get colder out and man im getting irritated with this issue...
Old Dec 15, 2010 | 10:22 PM
totaledTL's Avatar
Is the battery in good condition or could it be marginal? ??
Old Dec 20, 2010 | 11:10 AM
battery is still good. Can i use a multimeter or voltmeter to test for power at the switches?
Old May 6, 2011 | 06:28 PM
'03 Acura TL 80k
I have replace the main power window switches and i am still having the same issue. Could it be a wire issue that controls the windows from the driver side?
Old May 6, 2011 | 10:37 PM
totaledTL's Avatar
Dnload the service manual if you don't have one & chk. that section.
mada51589
Jan 9, 2025 04:40 PM
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
k6biv
Sep 10, 2015 06:37 PM
ahsm
Sep 9, 2015 08:35 AM
