2000 TL need help finding battery cables
I just had my battery replaced not too long ago. About 3 weeks into it, my car wouldn't start up anymore. I am assuming that the problem isn't the starter or alternator but I can't tell right now. I tried cleaning my battery terminals but it just won't stop leaking acid. So I cut some part of the insulation and noticed the corrosion has gone up pretty far.
Can someone tell me the part number I need to replace the battery cables? I am looking to replace both the positive and negative cables. Thanks.
go to a parts store and ask for a new set
or remove yours and carry in to match
no need for dealer trip on these
note for all- dip the ends of the cables in a coffee cup of hot water, optional- add baking soda to hot water for faster work
that will take care of the crud buildup
If its gotten as far inside as this thread says--then figure 10 years was a good life from the cables= especially if your battery vents at the top and pumps acid at the terminals (mine did)
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Mike Bertram
Sep 10, 2015 09:27 AM
