2000 TL Heater blower INOP
Old Dec 23, 2015 | 01:31 PM
MKV's Avatar
MKV
First time poster here and was wondering if you gents could help me out. 2000 Acura TL 200,000k, heater blower is not working. It seems to work fine when I start the car up cold and then it goes out after any amount of time(varying). Also at different times it has put off a really weak flow. Replaced the blower resistor and now it doesn't even seem to try to come on at all. With the old resistor you could hear a faint noise like it was trying to spin the motor but with the new resistor there is nothing. Ive checked all fuses and the harness to the motor looks clean. Thanks! MKV
Old Dec 23, 2015 | 10:43 PM
Chojun's Avatar
There's a recent thread about the blower motor.
But more than likely you'll need to replace your blower motor on top of the Power Transistor.
I recently did mine, and replaced the blower motor sub harness along with the transistor and motor. I would recommend doing that as well.
Old Dec 25, 2015 | 05:39 PM
01tl4tl's Avatar
ck the harness connector just under the glove box door, that likes to fail and take out the resistor and motor too! Have to look inside and on back of connections
if you get fan speed but low air flow and the filters are new, ck the thread on mix motor
See DIY section for more ideas
fixauto4b
Feb 3, 2021 01:22 PM
Robs252
5G TLX Problems & Fixes
Nov 29, 2015 02:45 PM
akbears15
Nov 27, 2015 08:51 PM
Ryan Ballinger
Nov 26, 2015 11:27 PM
AcraAdi93
Nov 26, 2015 12:19 AM
