1999 tl idle up and down
Old Aug 17, 2010 | 01:13 PM
ace1414's Avatar
Hi can anyone help! Code p0401....I remove he intake manifold and clean it with carburetor cleaner and put everything back,car ran find he nextday cel and tsc light are on? Rpm idle up and down help
Old Aug 17, 2010 | 07:18 PM
01tl4tl's Avatar
when you removed the manifold and TB- did you clean the IACV under the TB?
remove tb again- remove round cover on bottem- remove disc- clean-
should fix you up
on the manifold clean- you got the port clear all the way thru?
Old Aug 19, 2010 | 05:22 AM
ace1414's Avatar
Hey wondering if it's ok to spray iacv with sensor on it? Having a hard time removing sensor.
Old Aug 19, 2010 | 09:46 AM
01tl4tl's Avatar
you have to remove the round cover on the iacv then its internal parts come out for cleaning
Old Aug 19, 2010 | 08:34 PM
ace1414's Avatar
I'm having a hard time taking off the senior? Is there any trick
Old Aug 19, 2010 | 08:38 PM
ace1414's Avatar
I bought a sec throttle body with all the senior and still the same problem?
Old Aug 19, 2010 | 09:47 PM
fsttyms1's Avatar
you removed the intake manifold. Did you put the gasket on? did you damage the gasket at all? are the bolts torqued right?
Take a can of carb cleaner and start spraying around the base of the intake manifold and the TB with the motor running. does the RPM change.
Old Aug 20, 2010 | 02:20 AM
01tl4tl's Avatar
good call kris! that top gasket of the manifold gets put on upside down- looks like its correct but its not and blocks imprtant ports- causes idle to go up and down
solution- remove top cover and flip gasket over- match it to all ports in top cover, not engine side
always suspect the last work done on the car,,if not that- the thing done before that~
Old Aug 20, 2010 | 10:13 AM
fsttyms1's Avatar
Though he has a 99 which doesnt have that. But if he removed the IM and or TB either one of those gaskets could be leaking. Since he replaced the TB id like to know if he got a new gasket to go with it and cleaned the gasket surface really good.
Old Aug 20, 2010 | 10:37 AM
01tl4tl's Avatar
wow- I assumed samesame,,doh! on me twice in 24 hours!!
Old Aug 20, 2010 | 06:06 PM
ace1414's Avatar
I double check everything and clean it again? Still have the same problem.
Old Aug 22, 2010 | 12:44 PM
ace1414's Avatar
Ok after redoing everything again everything look fine? Now with the motor running I spray carb clearner around the TB gasket the motor idles funny and rite away cel and tcs light are on? Can it be TB gasket when bad?
Old Aug 25, 2010 | 05:38 PM
ace1414's Avatar
After change the TB gasket same problem ilde between 1 and 1 1/5. Now thing about change the throttle body?Acura dealer asking 5 big one? Can anyone tell me will it work!!
Old Aug 25, 2010 | 06:54 PM
01tl4tl's Avatar
what does the dealer say it needs?
is this used TB you installed known to be good?
Did you clean the IACV on the bottem of it before install? thats idle control probs 80% of the time
other possibles are throttle position sensor or vac leak
did you use a torque wrench to tighten all the bolts?
Its not very tight but must be in a 2 lb range or leaks occur
reset the ecu by pulling the CLOCK fuse on passenger end of dash for a minute or two
Old Aug 25, 2010 | 07:11 PM
fsttyms1's Avatar
If you spray carb cleaner around the TB does the idle still get funny?
Old Aug 25, 2010 | 07:12 PM
fsttyms1's Avatar
Also did you take the IACV off and clean it?
Old Aug 26, 2010 | 05:25 AM
ace1414's Avatar
Having problem taking out iacv any special tools I need.I have a sec TB and took out iacv and clean it? But the sec TB install idle reapply!!!
Old Aug 26, 2010 | 05:39 AM
ace1414's Avatar
I'll try again after work any special tools I need?
Old Aug 26, 2010 | 05:46 AM
ace1414's Avatar
Driving the car 15 mins idle fine? 30 mins then the ilde acts up. Is it cause iacv not clean rite
Old Aug 26, 2010 | 10:01 AM
01tl4tl's Avatar
might be heat related movement/expansion of parts- did you recheck every bolt- especially the TB to manifold connection and the intake manifold internal ones
Overtight is as bad or worse than too loose!
Whats spraying carb cleaner at the TB connection to manifold do now?
You had the manifold off, correct? for egr port cleaning?
whats the story of the replacement TB mentioned earlier- did that get installed?
IACV cleaned before install,??,I remember a sensor causing you problem before,,?
Old Aug 27, 2010 | 06:37 PM
ace1414's Avatar
I change iacv same thing? I took out the map senior out and notest o ring crack can that be he problem
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
