03' TL with weird misfire issue & runs hotter
Old Jul 24, 2011 | 11:36 PM
flyboiip26's Avatar
9th Gear
Question 03' TL with weird misfire issue & runs hotter
My tl has 24x,xxx.. I replaced my tranny at about
235ish, replaced all mounts...drove car for a few thousnd
Miles more and the timing belt snapped.. So i then replaced all belts
Waterpump crankseal and vtec solenoid gasket replaced plugs and coils
Then recently the car began to run hotter thus cycling the fan more
Frequently so the car begins to overheat on hot days with the ac on
throttle response is poor and idle feel as if theres a mysterious misfire
I kno i jus told a f'n life story but i figured more detail i include the chances
Of me gettin positive feedback wud be greater lol but PLEASE HELP i wanna take Care of this issue before i do my performance mods nd upgrades...
Old Jul 25, 2011 | 12:07 AM
flyboiip26's Avatar
9th Gear
Lightbulb
Please bump I'm a c tech at Acura but this is an annoying issue that I jus can't grasp I'm open to all advice and assistance... Wat should I check, clean, or replace to get rid of this issue thankz
Old Jul 25, 2011 | 10:51 AM
01tl4tl's Avatar
codes?
did a valve ck/compression test after broken timing belt? interferance engine!
what guage indication is `overheat` to you?
more than half- more than 3/4- redline?
loss of coolant? oil/coolant crossover of fluids indicating head gasket
fan temp sensor is pretty common on here- if driver side fan runs more than 2 minutes at shutdown - when temp normal, bad sensor
radiator condition?--some are getting flow issues-- and your car didnt get needed maitenance before you,,
older coolant goes acidic- aluminum rad internals...remember science class?
I realize as a tech you know these details, so they are for noobs in the future
Old Jul 25, 2011 | 10:53 AM
01tl4tl's Avatar
have you removed the intake manifold and done a full egr port and passage cleaning of the manifold
needs that every 75kmiles and you probably never had it!!
makes for strange running problems
clean the IACV inside TB unit while its all apart
egr system cleaning not found in acura sceduled mait, have to know about it from outside sources, like acurazine!!
Old Jul 25, 2011 | 10:55 AM
01tl4tl's Avatar
what does the senior tech have to say about it?
Old Jul 25, 2011 | 12:07 PM
flyboiip26's Avatar
9th Gear
When I replaced the timing belt and noticed the rough idle I got a c
Old Jul 25, 2011 | 12:22 PM
flyboiip26's Avatar
9th Gear
After I replaced the timing belt and noticed the misfire & overheating issue...I got a code for a misfire within the third cylinder checked all coils and plugs all were fine so I cleared the code and it never return but the symptoms remained I proceeded to do a compression test and all cylinder were within specs; i never allowed it to overheat in the red maybe about 3/4 all fluids are at specified levels and there no leaks...what direction should I go from here? I had a senior tech check it out and he mentioned cleaning the manifold and replacing the temp sensor an maybe replacing the radiator...help out Please
Old Jul 25, 2011 | 01:59 PM
flyboiip26's Avatar
9th Gear
I want to remove the intake mani thoroughly clean it and the egr hole & do the thermal spacer kit I been reading about, maybe a valve adjustment & seafoam can fix part of my Issue as far as the misfire goes... Any other suggestiOns folks ?
Old Jul 25, 2011 | 02:13 PM
flyboiip26's Avatar
9th Gear
Bump for adviCe & suggestions
Old Jul 25, 2011 | 04:25 PM
Karanx7's Avatar
Unregistered Member
You only get to have one thread =[
Old Jul 25, 2011 | 05:28 PM
01tl4tl's Avatar
valve adjust is possible
egr system plugged is probable and where I would start
since you are a tech, do it all at once,,
after soaking manifold and shoot solvent thru each port and the throat to soften carbon,
use a welding rod/wire coat hanger
poke it THRU the passage from one end of manifold down to the egr valve openings- and thru each egr port at cyl.
total flow is the desired result
whats your compression like? rechk after valve adjust
did you buy this car blown up?
rad would be next on the list if it gets hot with ac use or on hills, and you did the wp already
Old Jul 25, 2011 | 05:33 PM
01tl4tl's Avatar
ckd the vac lines to motor mounts- the stupid things are the ones we beat our brains over
ck codes again,,you may have a bad coil,,how did you test them,,moved around or ???
Old Jul 25, 2011 | 05:35 PM
01tl4tl's Avatar
he's new here and desperate for help--
but you get one break on the multi thread same exact subject rule!!!
Old Jul 25, 2011 | 05:36 PM
01tl4tl's Avatar
we agree- clean the egr system/ intake manifold
replace fan temp sensor
replace radiator
see other overheat threads where rad finally was the real fix
Old Jul 25, 2011 | 08:57 PM
totaledTL's Avatar
What about bleeding the air out since you had it open? Did you try that?
Old Jul 26, 2011 | 06:09 PM
flyboiip26's Avatar
9th Gear
@01TL4TL my compression from 1-6 cylinders are 142psi, 138psi, 141psi, 146psi, 150psi, 140psi...thats within spec becuz the max variation between the cylinders is 29psi, i didnt buy the vehicle blown up...the previous owner bought it from a leasing company and did plenty highway driving between n.y & c.t.... & @TotaledTL Bleed What Air From Where ? I've Read Thru A Few Threads And im jus gonna seafoam the oil and gasoline, Clean The EGR system & Manifold, do the thermal block spacer kit for the IM and TB, Valve Adjustment, Replace The Rad & Fan Temp Sensor...And See What Happens From There... I'll Stay Posted. Thanks
Old Jul 26, 2011 | 06:11 PM
flyboiip26's Avatar
9th Gear
Any Other Suggestions...Feel Free To Post, Theres No Such Thing As Too Much Advice
Old Jul 27, 2011 | 10:12 PM
totaledTL's Avatar
! Air from the cooling system- If the water pump was replaced then the system was open. Did you read the o/m? Why would you seafoam anything or just replace parts right away?
Old Jul 28, 2011 | 12:43 AM
01tl4tl's Avatar
sudden misfire must have a CEL, get the codes read at parts store
Old Mar 20, 2012 | 11:33 PM
kalick's Avatar
7th Gear
check the egr clean or get the codes read asap
Old Mar 20, 2012 | 11:53 PM
closetprisoner's Avatar
2000 Acura TL
Car probably already sold, thread is almost 8 months old..
Old Mar 21, 2012 | 11:20 AM
01tl4tl's Avatar
nice try kal.. but please see the dates on threads when posting
If you want to build you post count simply scroll down the main section of gen2 and the probs and fixes area,,plenty of places needing bona-fide help
If you are just guessing, or repeating what was said by someone just above,,especially someone with thousands of post/actual car repair experience,,,better to skip that thread
Welcome to acurazine,,Im sure you have good info to add!
mada51589
Jan 9, 2025 04:40 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
chrisr
Aug 31, 2015 08:24 PM
