02 type s will not start.
Old Mar 13, 2011 | 10:24 AM
02tlwhite's Avatar
8th Gear
I have an issue starting my car and thought I'd run it by the knowledgeable people here.
My wife's 02 type s won't start. She went to a b day party and came out... Nothing. The shifter will not move out of park, and the instrumen panel( mileage, trip computer etc) is blank. When you turn the key it cranks just fine but won't turn over. The battery is brand new so I know that's not the issue. The gauges don't even sweep back and forth when you turn the key.
I have no idea what the issue is. It's done this once before but it started after 30 minutes on it's own. I tried for over 2 hours this time and nothing.
Any help is appreciated. Thank you
Old Mar 13, 2011 | 11:32 AM
01tl4tl's Avatar
to make the shifter release: remove that little cover on right side of shift lever
Insert car key in slot and push down to release,,while holding brakes on of course!
then shift to N, remove key and insert in ignition- start
it can be from a failed brake light bulb- that will keep it from shifting
OR
the no start with it may be a blown master fuse
how many miles- timing belt been replaced if over 105?
anyone else had same prob and fix???
Old Mar 13, 2011 | 11:33 AM
01tl4tl's Avatar
even brand new parts can fail,,never trust a new battery or other part until retested
Old Mar 13, 2011 | 11:34 AM
01tl4tl's Avatar
are you getting the regular dash warning lights when key moved to On?
Old Mar 13, 2011 | 11:40 AM
02tlwhite's Avatar
8th Gear
I've checked all the fuses that I know of. Where is the main master fuse? Is it the 60a under the hood? The instrument clusters backlight comes on but nothing else. No brake warning, check engine light, nothing. All that is blank. I thought about it being a faulty alarm but I don't know how to disconnect it.
We did shift remove the shift release and shift to neutral. Still no start. I also tried to jump it just to test the battery, nothing. All lights come on, the nav comes on no problem. Just will not start. All it does is just crank
Old Mar 13, 2011 | 12:27 PM
totaledTL's Avatar
Green key light comes on/flashes? Tried another key?
Old Mar 13, 2011 | 12:44 PM
02tlwhite's Avatar
8th Gear
Green key light comes on. Did not try another key. I will do that.
Old Mar 13, 2011 | 01:07 PM
02tlwhite's Avatar
8th Gear
The green key light does not come on. Just checked. Nothing in the dash lights up.
OR
Old Mar 13, 2011 | 03:36 PM
02tlwhite's Avatar
8th Gear
Getting it towed to Acura.
Old Mar 13, 2011 | 08:36 PM
01tl4tl's Avatar
its not `seeing` the key--its got an encoder in them to know its ok to start the car
Old Mar 13, 2011 | 10:15 PM
totaledTL's Avatar
Didn't you try another key first?
Old Mar 14, 2011 | 01:53 AM
01tl4tl's Avatar
said he was going to try other key,,must not have worked
hopefully its just an alarm sensor part
Old Mar 14, 2011 | 04:30 AM
Karanx7's Avatar
Unregistered Member
Our gauges are supposed to sweep back and forth when we start? I know a couple cars do that, but I didn't know ours were supposed to. Is that a Type S thing?
Old Mar 14, 2011 | 07:59 AM
totaledTL's Avatar
Mine doesn't do that (S-type).
Old Mar 14, 2011 | 12:00 PM
01tl4tl's Avatar
maybe that is an indication of ongoing prob with ops car???
Old Mar 14, 2011 | 02:46 PM
02tlwhite's Avatar
8th Gear
Ignition switch was burned out. Got it replaced and everything works.
Old Mar 14, 2011 | 02:48 PM
02tlwhite's Avatar
8th Gear
That was a mess up. I didn't mean sweep back and forth, I meant move and light up. ( been riding in to many cadd's lately.)
mvidal6
ILX
Nov 14, 2015 07:43 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
agupta3224
Sep 22, 2015 08:08 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
