02 TLS FOG lights NOT working help =(
Old Nov 6, 2009 | 08:54 AM
jzhu625's Avatar
I have an 02 TLS, i installed HID for my fogs. it was working fine since the day i installed them, been over 3 months already, but last night when i try to turn on the fog lights both sides aren't working. i was trying to locate fog light fuse but no luck. anyone have a problem like this before? if there's a fuse where is it?
thanks
Old Nov 6, 2009 | 10:10 AM
TLin401's Avatar
'13 Hyundai Sonata
Are you getting the click noise from the relay?
Your switch may be fried.
The fuse is under the hood.
Old Nov 6, 2009 | 10:31 AM
jzhu625's Avatar
fuse is under the food? any one know if says FOG FUSE or some other words on it?
I'll check the switch later, i'll pop the switch out and connect those two wires. HAHAHA would that work?
Old Nov 6, 2009 | 10:39 AM
TLin401's Avatar
'13 Hyundai Sonata
Look under the top of the fuse box, it gives you a full diagram of what is what.
If the fuse is blown then the relay is bad.
Also you could probably pick up a switch for like $10.
Old Nov 6, 2009 | 10:50 AM
jzhu625's Avatar
I hope is the switch broken, or fuse. dont' want both HID go bad. lolz
Old Nov 6, 2009 | 10:54 AM
TLin401's Avatar
'13 Hyundai Sonata
I doubt the HIDs went bad.
IIRC the switch is a common problem on a 2G.
I know when my fog lights wouldn't turn on, my switch was the culprit.
Old Nov 6, 2009 | 10:59 AM
jzhu625's Avatar
UPDATEEEEE
so i took the fuse out and put a different fuse in it, and it WORK!
but only Driver size fog light is on, pass side is dead. maybe bulb or ballast is dead? means i gotta check wire?
btw, i did NOT check the swtich yet
Old Nov 6, 2009 | 11:01 AM
TLin401's Avatar
'13 Hyundai Sonata
Bad ground?
Change the bulbs out and see if it works on the working side.
Old Nov 6, 2009 | 11:06 AM
jzhu625's Avatar
Bad ground?
yeah, i'll have to do that later when i get home.
where can i get fuse?
Old Nov 6, 2009 | 11:10 AM
TLin401's Avatar
'13 Hyundai Sonata
Autozone
Old Nov 6, 2009 | 11:13 AM
jzhu625's Avatar
Autozone
sound sgood.
cause i might be two fuses.
the other 20 fuses 20AMP is popped too
Old Nov 6, 2009 | 11:22 AM
jzhu625's Avatar
Originally Posted by jzhu625
sound sgood.
the other 2 fuses 20AMP is popped to000ooo
this sucK!!!!
Old Nov 6, 2009 | 02:55 PM
totaledTL's Avatar
Replace with the correct amp. fuse only- there's probably a reason they blew, maybe a bare wire touching somewhere that you'll have to correct.
Old Dec 14, 2009 | 02:49 PM
missingH22's Avatar
I have an 03tls and my fogs stop working a few weeks ago...The green indicator light does not come on when you push the button...I have also checked the fuse under the hood, seemed ok...how can i check the switch?
Old Dec 14, 2009 | 08:49 PM
johnathan112usmc's Avatar
6th Gear
02 TL-S . My headlights are coming on one at a time or not at all. I have to flip it on and off and then one side lights up. I have to keep doing this until both sides light up. It seems like if the bulbs were out they wouldnt come on at all. Anybody else had this problem ?
Old Dec 14, 2009 | 11:17 PM
missingH22's Avatar
never mind I just jumped my battery after i let it die then they came back on...funny
Old Dec 15, 2009 | 01:32 PM
daquel's Avatar
You may want to wire in some diodes so you won't fry the switch in the future. Hid's if not installed with diodes will eventually lead to electrical problems. Too much current is coming up stream after turning them off.
Old Dec 16, 2009 | 03:39 PM
Type_S's Avatar
Same thing happen to me only it was the fog lights. I would check the plug itself where the ballast plugs in to the cars harness. When I checked it out, It was drenched with water and the contacts were all corroded. I cleaned them up and wrapped the plug with electrical tape. No more problems.
Old Dec 17, 2009 | 10:49 PM
totaledTL's Avatar
Put some dielectric grease on contacts prone to getting wet to prevent corrosion.
Old Dec 18, 2009 | 06:46 AM
daquel's Avatar
Good call
Old Feb 22, 2010 | 02:25 PM
Notorious7645's Avatar
hey i got HID in my fogs but the driver side only went out...when i try to turn them on the driver side fog just flickers and turns off but the passengers stays on...does anyone know if its my ballast or the fuse or something????
space_boy
ILX
51
Aug 15, 2017 12:06 PM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
