Yo Richiev6
Old 12-22-2008, 03:56 AM
  #81
Former Sponsor
Richie v6's Avatar
Originally Posted by phee
alright rich. i think you should break down exactly what the benefits of this harness are.
Overview
The swap module allows for the interfacing of a 6 speed manual transmission with a stock 5 speed automatic transmission computer from the TL, Odyssey and CL. This allows for automatic to manual conversions and for engine swaps.
Without the module the following feature will not work.
-VTEC
-Full rev limit
-Speedo
-Reverse lock out
-Reverse light
-Passing inspection due to CEL
The advantage over using the 03 CL 6 speed ECU.
-You keep your stock ECU.
-No need to change engine harness
-No need for expensive cam gears and sensors
-No need to tow your car to dealer to immobilizer programming
-No need to tear apart interior to change body harness
-Allow you to use TL and Accord 6 speed which are more plentiful and have less mileage.
-No CEL
Basically you can save lots of money using the harness and everything is simplified.
Old 12-22-2008, 07:30 AM
  #82
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Wish this was available 2.5 years ago
As for the 99 to 00-03 TL-P motor, Im not sure of the exact differences. The intake is the main difference, Stuff like the crank position sensor is the same.
Old 12-22-2008, 03:06 PM
  #83
spaz
tegkid's Avatar
Originally Posted by Richie v6
Overview
-VTEC
-Full rev limit
-Speedo
-Reverse lock out
-Reverse light
-No CEL
this makes a 6 speed swap so much more reasonable for joe shmoe. keep up the good work and keep us updated.
Old 12-23-2008, 01:38 AM
  #84
Your Garage
DC3328's Avatar
this joe shmoe is very happy
great work Richie v6
Old 12-23-2008, 02:04 PM
  #85
Unregistered Member
manafourme's Avatar
Do you have to remove the VSA?
Old 12-23-2008, 04:14 PM
  #86
Scooby doobie crusin
abptltypes02's Avatar
i think so but with the manual trans. depending on which 1 you go with its going to have LSD
Old 12-23-2008, 05:24 PM
  #87
I got the Shifts
phee's Avatar
Overview
-VTEC
-Full rev limit
-Speedo
-Reverse lock out
-Reverse light
-No CEL
perfect!. now ask specific questions that you have for us.
can a mod move this to the first post?
Old 12-25-2008, 12:05 AM
  #88
03' NBP TL-S
Leo Type-S's Avatar
richie is the man! this is exciting news..
Old 12-30-2008, 06:39 PM
  #89
6MT Someday..
twistedwedge's Avatar
this swap is looking more and more like me....good work man!
Old 12-30-2008, 10:49 PM
  #90
Clemson Tiger
Jake 6MT's Avatar
So do 99 guys who want the module need to buy the ecu from the 00-03?
Old 01-13-2009, 12:22 PM
  #91
poisx7's Avatar
so is this actually official.
How many have had this installed with the type s ECU and 6 speed.
For how long ??
Is this module begin TESTED & TRUSTED = (No, power loss in comparable to true 6 speed)
No Clitches (i.e true P N P). ???
sounds very promising..........
Time for a 6 speed swap then.
Old 01-13-2009, 12:29 PM
  #92
fsttyms1's Avatar
No... As stated before, these modules trick the existing ECU into thinking there is an auto hooked up
Old 01-13-2009, 01:20 PM
  #93
poisx7's Avatar
so since nobody that has really done it answered ??
i say fsttyms1, u have done this b4 , so ..... Did you have to remove the VSA when u did ur swap ?
Old 01-13-2009, 04:11 PM
  #94
fsttyms1's Avatar
I did because i used the CLS ECU. That motor and trans setup doesnt have it. Im sure you can keep it with the modules, but it may not work the same (and the motor may stall out ???? (no torque converter/auto trans to keep the motor running)???
Old 01-13-2009, 04:57 PM
  #95
i was thinkin... is the passanger side parking mirror not going to work anymore?
Old 01-14-2009, 01:55 PM
  #96
Former Sponsor
Richie v6's Avatar
Not sure about this one, I have the set up runing on a Accord right now and the ECU doesn't really miss it.
All the Acura 6 speeds have LSD the Honda ones do not.
Not sure about this one yet the 99 ecu is a beast I haven't messed with yet. Hopefully someone is willing to test it.
For how long ??
As of right now only me there are a few running the Odyssey ECU. There are about 4 cars waiting for this module once it comes out we will know for sure.
Old 01-14-2009, 02:39 PM
  #97
I got the Shifts
phee's Avatar
I'm willing to test out the module for the 99 my swap is in progress already. I'd be more than willing to work something out with you
Old 01-27-2009, 10:40 AM
  #98
Broke college grad
BlackuraTL's Avatar
So if this gets worked out and works what would the total be for a whole manual conversion now
Old 01-27-2009, 11:57 AM
  #99
spaz
tegkid's Avatar
$99.99
Old 01-27-2009, 12:54 PM
  #100
fsttyms1's Avatar
There is NO set #. Not every one is going to get the same price on parts. Some find good deals, some pull the parts themselves from the salvage yards, some buy new. As demand goes up so do prices.
Old 01-27-2009, 03:28 PM
  #101
Broke college grad
BlackuraTL's Avatar
Well yeah but for one right now without this module thing isnt it like a couple grand
Old 01-27-2009, 04:50 PM
  #102
I got the Shifts
phee's Avatar
research. there are 2 6mt swaps in the first page of the second gen section BOTH with parts list and mine even has prices
Old 01-28-2009, 02:40 AM
  #103
Former Sponsor
Richie v6's Avatar
Everything is working with the type-s ecu.
Old 01-28-2009, 02:43 AM
  #104
Former Sponsor
Richie v6's Avatar
The harness will run about $500 and I charge $1000 labor for the complete swap. The price of the parts depends on how hard you search.
Old 01-28-2009, 08:29 AM
  #105
fsttyms1's Avatar
Its a couple grand for just the parts even if you use module. The module will save you from having to buy a different motor/ecu/wiring harnesses and make life a lot easier.
Old 01-28-2009, 02:55 PM
  #106
Airborne MP 16th Unit
dasuddith33's Avatar
Sweet Good deal Richie!!!!!!!
Old 01-28-2009, 03:12 PM
  #107
spiro's Avatar
Is this harness is going to have a plug of some sort?
Splicing into the orig harness is how it will have to be installed?
Old 01-28-2009, 03:55 PM
  #108
6MT Someday..
I would imagine its going to be plug and play, no?
Nice work Richie!
Old 01-28-2009, 04:50 PM
  #109
I got the Shifts
phee's Avatar
good old rich
Old 02-09-2009, 09:22 PM
  #110
spiro's Avatar
Trans gave up on my 2003 tlp. How is the module test going?
Old 02-10-2009, 12:12 AM
  #111
I got the Shifts
phee's Avatar
working with the tl-s and ody ecu.
Old 02-10-2009, 02:57 AM
  #112
Former Sponsor
Richie v6's Avatar
Nice work Richie!
I do plan on offering a complete engine harness for those that do not want to modify their own. Or doing it as a service.
Old 02-10-2009, 03:01 AM
  #113
Former Sponsor
Richie v6's Avatar
Everything is working fine the first module/harness shipped out today to Paul he will install it in Nates car. Hopefully it is problem free and I can start mass producing these. So far it is working fine on the TL-s and Odyssey ECU. Next I will work on something for the 4 speed automatic transmissions.
Old 02-10-2009, 06:42 AM
  #114
spiro's Avatar
Can you elaborate a little more on what needs to de done in order to install this harness? Or posible post the installation procedure.
Old 02-11-2009, 09:37 AM
  #115
JCharged's Avatar
lovely.
Old 03-09-2009, 10:37 PM
  #116
I Blaze Up In
bigmark89's Avatar
Im bringing this thread back, and I really wanna know the installation process. Does it just plug right into the ECU or is there splicing involved???
-Mark
Old 04-26-2009, 01:13 PM
  #117
vanirl's Avatar
Wow
This is awesome! I wish Acura would have produced the TL with an optional 6spd manual like they did with the CL. In any case, thank God for techies like RichieV6, fatyms, and others who are making it an aftermarket possibility! I'm sick and tired of my automatic transmission..and I miss driving a stick-shift car. The economy isn't the friendliest right now, but as SOON as I have the money togther to do the swap, it will be done.
RichieV6 - you said you'd charge $1500 for the module and the labor. What state do you live in, and how long does it take to complete the swap?
And is there anyone else who would consider taking the swap job?
Old 04-27-2009, 10:08 AM
  #118
JCharged's Avatar
^ Richie is in IL.
Richie and I could recommend someone to you if you don't plan on driving up to IL.
Old 04-27-2009, 11:20 AM
  #119
I got the Shifts
phee's Avatar
if you wanna drive to atlanta, i can do it for cheaper than that
Old 04-27-2009, 11:34 AM
  #120
Low & Slow w/Dubz On My
ZEUS'O3TL's Avatar
Richie as an awesome guy...met him at the Illinois meet Saturday...
Quick Reply: Yo Richiev6
