tls throttle body
Old Oct 20, 2008 | 02:37 AM
thinhthan's Avatar
tls throttle body
would putting a tl-s throttle body on my 99 tl-p do anything?
Old Oct 20, 2008 | 04:58 AM
Rajca's Avatar
wham bam thank you ma'am
not unless youd put a tl-s intake, and manifold with runners on. the manifold inlet would still be the same size so it would "block" the air some. and the intake would restrict it.
Old Oct 20, 2008 | 07:03 AM
fsttyms1's Avatar
You would have to like stated above change the IM opening or IM to match or you will still have a bottlekneck
Old Oct 20, 2008 | 03:43 PM
thinhthan's Avatar
so i would need the IM and the intake? is that it? whats runners?
Old Oct 20, 2008 | 04:05 PM
fsttyms1's Avatar
use the search button and find the threads where people swapped Intake manifolds. You need the upper AND lower IM. If you go with the type-s manifold you need to get a RPM switch to activate the 2nd stage intake
Old Oct 20, 2008 | 04:07 PM
thinhthan's Avatar
would this mod even make a different
Old Oct 20, 2008 | 04:36 PM
Rajca's Avatar
give u some hp. my guess 10-15hp
Old Oct 21, 2008 | 09:05 PM
DUB_TL's Avatar
I have this mod done except for the fact that I did it pretty half assed... I just left the second TB open since I never got around to buying the rpm switch. Still felt like I gained hp, maybe even too much since my trans went out not too long after I did it. Anyone have the rpm switch hooked up??
Old Oct 21, 2008 | 09:49 PM
Rajca's Avatar
your trans didnt blow do to you adding on the tb, it was on its way out already, with or without what u did.
Old Oct 21, 2008 | 10:03 PM
sbuswell's Avatar
I need 2 more gears
yeah 10 more HP isn't going to fry our tranny's, maybe 100 extra HP will get us there quicker, but I doubt by much.
Old Oct 22, 2008 | 02:49 AM
thinhthan's Avatar
so can someone list everything i need to do this conversion please.... and what else would i need to make it a "type S"
Old Oct 22, 2008 | 04:50 AM
Rajca's Avatar
a whole new engine, type s has diff pistons, crank, cam, intake manifold, intake manifold runners, throttle body, vsa, bigger intake tubing.
Old Oct 22, 2008 | 01:04 PM
DUB_TL's Avatar
Oh I know that...not the first time I have delt with the crappy trans we got. My new one should be getting here tomorrow anyway.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
