TB bypass mod
Old Apr 18, 2011 | 02:50 AM
HairyMonkey019's Avatar
TB bypass mod
Has anyone done that throttle body bypass mod on the 2g tl???
I want to see a DIY if anyone has done it, and what are the gains?
Old Apr 18, 2011 | 08:17 AM
fsttyms1's Avatar
What bypass mod? You mean removing the coolant lines from the TB?
Old Apr 18, 2011 | 10:40 AM
jjashaa's Avatar
Avant Garde Wheels
you'll be the first!
Old Apr 18, 2011 | 11:14 AM
Karanx7's Avatar
Unregistered Member
Gains are increased response. If you live in a cold climate, might not be safe to do it.
I believe that you just remove the inlet/outlet and connect them together.
Old Apr 18, 2011 | 02:40 PM
i believe so. i looked it up on google and i only found a tsx DIY.
SOOOO, if anyone has and ever done it, can you please do a DIY???
Old Apr 18, 2011 | 06:34 PM
01tl4tl's Avatar
its in the directions for thermoblock install --iirc
optional to do it with that mod,,but not needed in general for street drivers
yes its like bypassing a bad heater core- the hoses have to get connected together so the coolant still flows thru them, not blocked at the end
Old Apr 18, 2011 | 06:36 PM
01tl4tl's Avatar
here is the diy list--spend a few hours going thru it for way more than you want to know about modding or working on the TL
saves posting new threads on old subjects
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old Apr 18, 2011 | 07:25 PM
sbuswell's Avatar
I need 2 more gears
I've done this before and didn't really notice much. Maybe a little, but not enough to change it over every 6 months. It's very easy to do, but only should be done in warm weather. If it's cold your TB will freeze up and that just sucks ass in the winter. Best way to do it is to disconnect both hoses going to the TB and get a larger diameter hose, put the two hoses that were on your TB into the larger hose and using hose clamps tighten it just enough so you can't pull them apart. You don't want to overtighten and restrict the coolant flow though. Run the engine up to closed loop and check the hoses to see if anything is leaking. After a longer drive check them again. I would check mine every day for about 2 weeks and if all was nice and dry I'd stop.
Old Apr 18, 2011 | 08:53 PM
https://acurazine.com/forums/showthread.php?t=706083
ha, i already know about the DIY list
Old Apr 18, 2011 | 08:54 PM
do u mind putting a picture of how you did it?
and what size hose would i need?
Old Apr 18, 2011 | 10:32 PM
01tl4tl's Avatar
if you already know about the diy list ---why are you making a thread on this
its been covered more than once on azine
if you cant figure out how to run a bypass ---dont do it!
Old Apr 18, 2011 | 10:40 PM
Karanx7's Avatar
Unregistered Member
We all gotta start off somewhere.
One year ago, I attempted my first DIY when replacing my low beams. I almost created an account JUST to ask how to disconnect the battery. Seriously.
Old Apr 18, 2011 | 10:45 PM
Originally Posted by karanx7
we all gotta start off somewhere.
One year ago, i attempted my first diy when replacing my low beams. I almost created an account just to ask how to disconnect the battery. Seriously.
lolll!!!
Old Apr 18, 2011 | 10:48 PM
https://acurazine.com/forums/showthr...4#post11434934
are u talking about that thread btw?
but u need to chill, i'm pretty new to working on my engine.
so, if you can be a nice understandable Aziner, please don't make sport of me
Old Apr 18, 2011 | 10:54 PM
Karanx7's Avatar
Unregistered Member
Naw dude, you just met the dark side of the moon. Tom is usually pretty welcoming/helpful to the newcomers. It's me that yells "Read the effing owner's manual!!!"
Here's the master DIY list: https://acurazine.com/forums/showthread.php?t=706083
Here's the thread Tom was talking about: https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
That thread will basically show you how to remove the intake manifold and the throttle body. You just need to remove the two hoses connecting to the throttle body, and connect them together.
Old Apr 19, 2011 | 01:14 AM
Here's the thread Tom was talking about: https://acurazine.com/forums/showthread.php?t=615644
lol, well thanks!!!
but i apologize if i didnt understand what Tom was tryna tell me, i think i got confused
Old Apr 19, 2011 | 08:08 AM
fsttyms1's Avatar
There are DIYs on it. If you use the advanced search button and type "coolant bypass" then select 2g tl you will get many responses.
One of many.
https://acurazine.com/forums/showthr...coolant+bypass
Old Apr 19, 2011 | 02:03 PM
Mr. Maker's Avatar
This thread sucks..
Old Apr 19, 2011 | 09:07 PM
sbuswell's Avatar
I need 2 more gears
Originally Posted by Mr. Maker
This thread sucks..
LOL.
Old Apr 21, 2011 | 09:51 AM
01tl4tl's Avatar
why? any thread that ask the user to initiate some action on their own,,rather than hold their hand and explain,,,, again,,,,how to do something thats already well covered??? sucks??
Point them -link them if possible, direct to DIY section,,,
teach them how to `fish azine` and,,,,they will make fewer post on covered subjects
Old Apr 27, 2011 | 10:14 PM
mrbustrbrown's Avatar
ive actually done this pm me ill send u picks keeps the throttle body from heating up as fast dont know of any gains but i like cooler air than warmer air going into my intake
Old Apr 29, 2011 | 11:20 AM
01tl4tl's Avatar
a safer option is one of the thermal heat spacers for the TB, which also lengthens the the airflow distance,,a slight bonus while retaining cars driveabilty
to maximize the reduction of heat absorbtion in the manifold- there are 2 excellent makers of spacers,
the heat radiating UP from the engine into the manifold is more hurtful than the TB heater system
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
