maxbore.com for throttle body and manifold work?
Attorney- Will Sue 4 Food
http://maxbore.com/
Anyone ever sent off their TB to get bored out & Manifold to them for opening port matching?
I just got a reply from the guy @ maxbore. He can bore it to 4mm over stock and the manifold port to match. I am going to send it off and will post results. I plan on doing dyno test for first time, but its gonna be after I can get the damaged header replaced with the comptech knockoffs, straight pipe, plugs changed, and obviously TB back, and likely f/ic and tuning. Will have all that done by the end of the month.
Jedi Apprentice
Jorge does AWESOME work. I had him bore out and portmatch my Tb when i did my F22/F23 IM swap on my '97. Can't say enough good things about him. You'll be pleased with the work, but i couldn't say anything about the gains. Never got to dyno mine with the nice manifold...
I don't know $$ total yet. I'm auto illiterate and even my mechanic couldnt tell from his website if he just bores out the TB and upper intake connection to match, or lower intakes as well. If he dosnt do it all then theres a place that jotech in garland will send part of the job out to, but im sure they wll charge more...
Lead Footed
Don't know, but I used King Motorsports to bore my TBs out . . I think it was 3mm, but can't remember. I didn't catch whether you had a Type S or base. If you have a Type S you will need to bore out the traction control body as well. Either way, you'll love the gains . . I did.
And looking forward to the dyno results.
http://www.kingmotorsports.com/
By the way, saw that you are in the Dallas area . . you should check out the Texas Meets thread and drop in.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Ruf
02 WDP TLS Black Interior w/ Black Grill Inserts & Cleared Headlights
**1/4mile 14.46 @96.07MPH – 14.23 corrected; (45-70mph test - 3.5 secs)
17x7 Konig Appeals SMF – 16.8lbs each
P225/45ZR-17 Sumitomo HRT AS P01- (Kumho Ecsta SPTs for track)
CT Icebox, Custom RamAir, CT Sways & Springs
3nd Gen Innovative Motor Mounts – Front & Side Only
Bored out Intake & TBs, Mugen Cooling Mods & Thermoblok
Ceramic Coated XS Headers & Random-Tech Hiflow CAT
NEO Anti Freeze & 5w-20 oil w/Militec-1
Tranny #3 Installed 11.17.2008
Note: (** 1/4 mile times were before headers, Hi-flow CAT, IMMs, Bored out Intake & TBs mods)
Ruf
2000 acura tl FPR
I pulled the traction control body as well. Waiting to make sure he can do all the work. How much of an increase will this give, did it feel more or less than installing headers?
Lead Footed
J35 _ 5 Speed A/T
I used Maxbore.com for my T/B. $105 for the service. He had a good turnaround with mine, 6 days from shipping it to him and receiving it back from him.
Jorge does good work. He has good feedback over on HondaTech.
* Had NVA-AV6 bore out my I/M port rather than Maxbore.com
Heres some pics. I cant get ahold of maxbore and need to ship tommorrow. I am guessing now he does not bore out the lower intake and I need to figure out if boring out the lower intake would help and who to send it too.
![](http://img513.imageshack.us/img513/8020/cimg0223.th.jpg)
This is my TB of course and the other part is Traction Control TB/TB adapter? Both these would goto maxbore?
![](http://img13.imageshack.us/img13/1289/cimg0222x.th.jpg)
This would goto maxbore as well to match up with the TB?
![](http://img15.imageshack.us/img15/825/cimg0221gd.th.jpg)
What do you call the above, this is just the lower intake manifold right? and will it help if this is bored out?
you can ship your tb to p2r to get it bored also. They also sell the ported intake runners. http://powerrevextras.com/catalog/pr...roducts_id=152
Lead Footed
Some day this will be one more mod I'll do.
Ruf
I should have mine done by this next sat...besides the hassle of sending this off to get the work done, this is pretty cheap mod for the HP gain if its better than headers.
Jedi Apprentice
I don't think he does lower manifold porting because the main way that would benifit you is if you get the lower IM ported to match the heads. THAT would be a PITA unless you're doing a real heavy build. when i sent mine off for my f22/23 i just got the upper IM ported and i noticed a fair gain. I don't know if you'll see that much of a gain on a stock motor but one with I/H/P you may see a better gain.
Lead Footed
Yes . . . really. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
It produces power from the moment you hit the gas and goes through redline. Headers give you a big number, but in a relatively small range . . and on the very lowend you initially produce less HP with headers. All I can say is that once I did this mod I was breaking tires loose from a 30mph punch. There was one odd initial problem. When flooring it in 1st or 2nd at 4500rpm+ it seemed to rev real fast and then before redline it would act like the traction control kicked in. I thought it might have been sucking air so quickly that it was pulling the TCS butterfly shut. It did this for a while and went away. Not sure what it really was . . . maybe the ECU needed to relearn some things.
Oh, I do have a ram-air set up and that plays a factor in the gains as well. PM me sometime and we can meet so I can show you how I did the ram-air. Or wait until I get around to repairing the ram-air intake and I'll post pics.
Ruf
Ruf
ughhhhh...I'm still, yes still, waiting on both TB's and upperintake from maxbore.com, new intake runners that are getting bored out, thermal gaskets [tb and manifold], DC headers, test pipe. I miss the TL...
Great, just great. Today after waiting for almost two weeks for my intake runners, without any other heads up, I just get a notice from paypal of a refund from P2BR racing for the intake runners they had supposedly been waiting to get from Acura to bore out, with a simple note that the pricing on these had increased and they were going to have to discontinue them from thier site. Now after a February 7 order that was supposed to by recieved by that Friday, I will be lucky to get the remaineder of my order [my thermal gaskets]in by this Friday.
Update and please opine
Ok, so Ive got everything except the lower intake runners, which are being bored out today and next dayed to me. I can get this all done sat, but....I realized that porting the intake runners without porting the head runners/heads to match won't give near as much increase. I need to decide if I want to pay my shop nearly $800 to remove and place the heads and a machine shop $600 to port and polish the heads/runners to match the intake runners [this includes custom gasket]. With all possible bolt ons, ported tb and upper intake, ported intake runners, porting the heads/runners is an additional $1,600 that might be better served just throwing down the $3,950 for the C/T S/C...thoughts?
hmm 1600 is alot. I saw a ct sc in the bm for like 1800, no need to pay 4k for a new one imo. If I was gonna spend that much i would probably go the 3.6l swap route for n/a or get a ct sc or custom turbo.
Your Garage
dont get the comptech supercharger, get this (delete the space between v and 6)
http://www.v 6performance.net/forums/showthread.php?t=179175&highlight=eaton+m90
as to the porting, have you tried shopping around for a better price? i didnt know it was that expensive
Yep, I'm going that route...I'm putting too much $$ into this, i was just getting a timing belt job and it turned into more modding than i had planned. With 110K miles my TL is supposed to be the daily driver to the new bmw 5 series im about to lease....
http://www.youtube.com/watch?v=i-Jl-Slj_oI
I would say for the $$, getting your throttle bodies bored out and the upper intake to match through maxbore.com is worth it!! I would say the throttle response on the low end and especially when vtech kicks in is outstanding and comparable to headers. I know the video is upside down, oops.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
